Cag leaking gas from overflow tube HELP - Pocket Bike Forum - Mini Bikes
post #1 of 41 (permalink) Old 07-20-2008 Thread Starter
Angry Cag leaking gas from overflow tube HELP
I posted in the general section but cant get no help.
anyways i bougt a cagllari not long ago and rode it about 10-15 times so far its only like 2 weeks old.
anyways if i even turn the switch on the carb to -on- then gas leaks out of the overflow tube. i have NO clue why its doing that. also i took apart the gas tank and the tank is not leaking -i just wanted to make sure- but can someone tell me why gas would be dripping out of the overflow tube when i turn the switch to On???? please help me out ty.
Racerkidd14 is offline
post #2 of 41 (permalink) Old 07-20-2008
Fritz
Guest
Posts: n/a
Re: Cag leaking gas from overflow tube HELP
Please try using the Yellow Search button. If you had searched on "gas leak" you would have found the info below. This happens to most Cags. The quick fix is to bend the float arms down a bit. Good luck. -Fritz
"Is the fuel coming out of your drain tube? If so you have a stuck or clogged fuel float in the fuel bowl. If that's the case it's real easy to fix and I think every Cag owner has experienced this problem. Turn off the fuel petc0ck. Take the 2 screws on the bottom of the carb off and slowly pull the bowl off being careful not to tear the gasket. Once off you'll see a white plastic donut (the float) and a 2-prong metal arm hinged to the carb. When that Fuel bowl is full of fuel the float with rise and put pressure on the Float Arm. That float arm is attached to a valve that opens and closes allowing fuel in. Look under the float arm at the valve and see if there is any debris in the valve. Sometimes plastic shavings or pieces of gasket get clogged in here. Blow on it a few times just to make sure and move the arm with your finger to ensure it moves freely. Now, take the float arm and bend it ever so slightly down away from the top of the carb. This will allow the float to apply more pressure on the valve. Now put the float back in the bowl, flat side up, and reattach the bowl to the carb. Make sure the screws are tight enough that the gasket is sealed but don't over tighten b/c the carb is soft aluminum. Now turn on the petc0ck and you should be leak free!"
post #3 of 41 (permalink) Old 07-21-2008 Thread Starter
Wow, you must really know your stuff because this worked just great im leak free and set to hit the road again thank you sir
post #4 of 41 (permalink) Old 07-22-2008 Thread Starter
Unhappy Re: Cag leaking gas from overflow tube HELP
well i didnt want to be a pain in the but so i just said it would work ect. you were right though i think its leaking becuse the float or what ever.
but im only 14 and i got this bike as a big gift and i have noone else to help me out on it. can you please post a vid of how to fix this problem or find a vid for me pleeease.
i looked up tutorials for -bending the float arm or w/e back down- but cant find any.
im worried that if i screw something up there could be alot bigger problems =/.
i just wish i could find a quick vid on how exactly to get to this so called -float arm- and bend it back -down-. =/ help me please. thank you so much =/.
post #5 of 41 (permalink) Old 07-22-2008
Council Member
Juanitoboy93's Avatar
Send a message via AIM to Juanitoboy93 Send a message via MSN to Juanitoboy93
here this should help, every thing is labeled so u can get a basic understanding
https://www.pocketbikeplanet.com/f167...ial-41644.html
Juanitoboy93 is offline
post #6 of 41 (permalink) Old 07-22-2008 Thread Starter
me and my dad looked at the tutorial a few weeks ago and honestly have no clue what to do =( thats why i was waiting for a vid or something i know im apain in the but its just that i dont wanna screw nothing up ya know
i havnt rode it in probly a month now ive just been waiting around =/ theres also no shops or nothing around here so i cant have a shop do it for me =/. im just gonna have to wait till someone posts a decent vid of how to fix it otherwise its gonna sit where its at right now for a few more months =( oh well ty anyways though i appreciate it.
post #7 of 41 (permalink) Old 07-22-2008
Fritz
Guest
Posts: n/a
Kid, we've all tried to help you, but you've got to try somethings for yourself. You need to learn by doing, and you can't really mess things up and make them worse. The tutorial is good, just take off the bottom of the carb and remove the float. The part in the pic is the float arm or as some call it the fork. Just bend the two arms down a bit, like a 1/16 of an inch. You don't even have to remove the float arm to bend it.
post #8 of 41 (permalink) Old 07-22-2008
Council Member
just take it apart your self, u have to learn someway, u cant make it worse, and if something goes wrong just come back here and ask
post #9 of 41 (permalink) Old 07-23-2008 Thread Starter
oh well ttyl thanks all bye bye
post #10 of 41 (permalink) Old 07-26-2008 Thread Starter
Talking Re: Cag leaking gas from overflow tube HELP
All, i have to say is wow... i was kinda worried id screw something up but i went out there fixed it in prob under 5 minutes just had to bend the arms down =D.
thanks for the encouragement and im glad i went out there to fix it.
but i have another question =/...
this cagllari is about 4 months old... i did proper oil mix ect. -for the break in- and stuff and followed all the directions untill break in was over.
however whenever i give the bike more then 35% gas it starts shaking and the muffler is rumbling terribly then if you give it even more after about 50% it just stalls out. i AM using proper gas / oil mix and did all the break in stuff. it goes about 25-28 -next to my brothers car-. its stock also.
i was told before that as a -stock- cag i am very lucky to have it going 25+ but why is it that if i give it more then 35% throttle it stalls? i feel if i could give it more it would be going like 40 lol.
MY SECOND QUESTION IS -before im completely done =P.. is..
there is a -black cover- so to say.. on the back of the carb by the tire ok.
i had a X7 Bullet before and when i took this -black cover- off of that bike it went ALOT faster almost as if it was a speed govener.
but i was told at the shop its just that when you take the cover off there is pros and cons about the risks.
by taking it off you let alot more air in meaning -IN MOST cases- more power. i want to know if its the same deal with the cag? he said its risky becuse if the cover is off then theres a chance of dirt rocks road debree ect. getting clogged in there =/. but im wondering if i take it off will it get more air and go alot faster like my x7 bullet did???
thanks for all the help to this point and im sorry for being a pest before this will be my last trip here. -hopefully-
ty all i really really do appreciate this ALOT. ty
Council Member
take the black box off and just use a panty hose for a air filter, but buy one of these, way better than that box
af24x - Pocketbike Angle Filter Kit
then select the color u want, and where it says velocity stack, choose the second one, it says 47cc stock carb
post #12 of 41 (permalink) Old 07-28-2008 Thread Starter
wow this is exactly what i was looking for. but it looks like my carb is so close to my back tire that if i put this on the carb it would be rubbing against the back tire =/. oh well ill try it. ty.
hei my carb is also leaking i took your advice and opend it up but i dont know evactly what i need to bend think any one can send me a picture of what it looks like??
jazer wun is offline
Hooligan
SpyGuy's Avatar
Images: 23
If you've just pulled the bowl off your carb, and are looking at it, there should be a fork thing inside. That's the piece that needs to have the arms bent down a little - not much, maybe 1/8". Your float comes up against these arms, and presses them upwards. The needle on top of those arms gets pushed upwards into its tube, and stops the flow of gas.
SpyGuy is offline
ok cool its workin good thanx.... i also have another problem...when i turn it on sometimes it revs on its own but then there are time where its perfact... the idol sems to be at a good place but when i give it alittle gass and let go it will keep going even after i let go...
Hooligan
SpyGuy's Avatar
Images: 23
RcaerKidd: that "black cover" between the carburetor and the rear tire is your air cleaner. It protects the mouth of the carburetor so that nothing gets in it like dirt, dust, rocks, etc. Try Juanitoboy's trick with the pantyhose, or if you feel you HAVE to have something back there, try MY trick with the Altoids box (ya gotta work on it some, but it's kinda cool and goofy and IT WORKS!)
Jazer: sounds like your throttle is sticking a little.
SpyGuy is offline
ohhh... so you know how i can fix this?? i relly dont wana eat a wall on this bike doing 15 lol like what can i mess with to fix this?
Hooligan
SpyGuy's Avatar
Images: 23
Probably a kink in the cable someplace, or just sticking - try shooting a little WD-40 down inside the cable housing.
SpyGuy is offline
alright thanx =] ill try it...ohh and not to bother.. one more thing do you know if its best to put gas in the tank then the oil or put the oil then the gas over the gas?
Hooligan
SpyGuy's Avatar
Images: 23
Actually, it's best to mix it OUTSIDE the tank in a mixing bottle or a 1 gallon gas can. I get my bottles of 2-stroke oil (I run 32:1) from my local auto parts store, pour one of those into an empty gallon gas can, then take the can to the pumps and fill it up. Hasn't failed me yet....
Hey, it's okay - the stupidest question is the one you didn't ask ....
SpyGuy is offline
