extended swingarm for x19 - Pocket Bike Forum - Mini Bikes
 1Likes
post #1 of 25 (permalink) Old 06-16-2018 Thread Starter
do anyone know where I can get a extended swingarm for my x19. I have tried pocket bike unlimited but starting to think they went out of business since no one answers the phone or emails. I tried to just purchase one off there website and it will not let me add it to the cart. Any help guys
repsolking is offline
post #2 of 25 (permalink) Old 06-16-2018
Re: extended swingarm for x19
Forget PBU, I have a 2008 X18, very hard to find frame or body parts since they are no made anymore. Most people make their own swing arm from the stock one.
post #3 of 25 (permalink) Old 06-16-2018
Welcome to the forum....
The X15/19 rear swingarm is pretty tricky to extend without boxing it in seeings its mainly a C-channel construction.........
Best bet is getting a pitbike rear swingarm and modding it to fit..
Even if PBU was still doing rear extended swingarms they would tell you its gonna take 10-12 weeks to make and another week to ship it out plus they'll want you to send them your rear swingarm first because all they'll do is extend yours by melding two swingarm together then sending it back to you.......
If you want a lil longer swingarm than in the picture look into the CRF70 extended swingarm.........
post #4 of 25 (permalink) Old 06-16-2018
On my X15 Dragbike I used a rear swingarm from a 125cc 2 stroke dirtbike....
post #5 of 25 (permalink) Old 06-17-2018 Thread Starter
What year make and model 2 stroke pit bike you used
post #6 of 25 (permalink) Old 06-17-2018 Thread Starter
An will a x18 swingarm work on a x19
post #7 of 25 (permalink) Old 06-17-2018 Thread Starter
I will be using my x19 for drag racing I switch the motor to a 140cc.... I have another that I'm putting together just to have fun on but body parts are really hard to find
post #8 of 25 (permalink) Old 06-17-2018
Its not a pitbike...Its a KX125 rear swingarm...Its not a plug n play install either...The trunions needed to be milled thinner and then I modded both trunions to house 3 stacks of roller bearings in each trunion for the swingarm pivot.......
The X18 rear swngarm WONT fit...It has a bar with roller bearings that connects the left and right side of the frame together.........
If you go on the PBU website you should be able to easily tell that the X15/19 rear swingarm isnt compatable with an X18 and Vice versa............
post #9 of 25 (permalink) Old 06-18-2018 Thread Starter
Underatood thanks for clearing that up... But them swingarm on pbu I cant add to my cart an they wont answer to phone I will keep trying. Or get kxx125 arm
Stop trying PBU...Its a lost cause..They havent done legitimate business since 2007/2008...........
The website is there just to generate $$ from internet traffic.
You can try doing the KX 125 rear swingarm.....The hardest part youre gonna find is deciding on how much to cut from each side then finding the bearings to go where the dirtbike swingarn bearings go which will need to be slightly bored out a lil larger and with a lip left to trap the bearing on one side so they dont slide all the way through rendering the rear swingarm to shift side to side slightly and you dont want that with a dragbike..
Another thing youll have to do is make a reducer/slider setup so you can use the stock rear axle in the wider slider area on the dirtbike swingarm...........
Back when I did my dragbike in 08 I already had the rear swingarm and my dad still had his machine shop so for me it was easy to choose the budget build route............
Also on my dragbike I didnt use a shock,,,,The rear was locked solid with a static bar that looked like a shock........
If I can find my build book I can find out the bearings I used but Im almost certain they were either wheel bearings for a cag or an X1...Im pretty sure they were rear wheel bearings from an X1 with the 12mm axle............
Id go with the CRF70 extended swingarm from T-Bolt....Its around the same ballpark price as the PBU unit maybe even cheaper..............
The best part about the t-bolt unit is it will literally bolt right in with the easy fabrication of some spacers also to mention being substantially lighter than the PBU unit because on a dragbike every pound shed adds to launch aswell as acceleration....
Another point to touch upon is the chain and sprockets.......
I used a #428 o-ring chain....It has about 700lbs more strength than the 420 chain because the links on the 428 chain are a lil thicker so it will take the hit of the launch alot better also due to the help the o-rings provide aswell.
Antnice2x's Avatar
I still have parts I have a x18 frame and a x15 frame also have a couple x15 rear tail plastics fairing if interested let me know
Antnice2x is offline
post #12 of 25 (permalink) Old 06-21-2018 Thread Starter
Thanks but I have a full x18 and another just a frame I was going to build to drag race I just need a gas tank an plastics
Real drag bikes don't have a rear shock, just extended rear arms with braces and a wheelie bar.
post #14 of 25 (permalink) Old 06-23-2018 Thread Starter
So I been searching for fairings, swingarm, general info of what people have done for there x15 or x19.. Then I come across a post on facebook a guy is selling a yamaha super pocket bike. I'm new to this so I had to see what this was so I open it an behold its a fully dress x19 fairing in great shape just painted a ugly color ... But why the yamaha in the subject
post #15 of 25 (permalink) Old 06-23-2018 Thread Starter
Then I found out some how some way this guy shove a 225 yamaha dirt bike motor in a x19... Only problem was no room for the gas tank an battery... He had the 225 gauges on an working an only wanted 300 I bout it but with the ugly exhaust I had to hear it run... He rig up some gas bottle jump it off took the battery a loose an rode it then told me to ride it. Its got a 110 dirt bike rear swingarm modded of course. But everything was align an freaking insane fast... Don't know how safe this is but gonna be fun till I get hurt. I just got to fin some where to put the battery an a gas tank to fit under the cover
post #16 of 25 (permalink) Old 06-23-2018 Thread Starter
Left side. I will have to pull it apart when I get home
post #17 of 25 (permalink) Old 06-23-2018 Thread Starter
Vertical motor in here with only a couple inches for gas tank
post #18 of 25 (permalink) Old 06-23-2018 Thread Starter
Only thing is this ugly exhaust
Killer, I like it, its a little Crazy, but aren't we all, lol. Put a gas tank in the tail section behind your seat. To bad its not a kick start. Might need a small Lipo battery for starting. I paid $22 for a 12v. 8,000 mAhr. or about 8 amps I believe its about 1/5 the size of a reg motorcycle battery.
Put a Honda NSR gastank or a Yamaha YSR gastank..Maybe a Derbi or Metrakit.....It wont take much to get it to work....
The X15 was modeled after the Benelli Tornado Tre 1100.
If thats gonna be your dragbike you only need as much fuel as it takes to go from A to B and back ...A cag tank RTV'd to the tank cover will work good..........
