Help with Bike ID - Pocket Bike Forum - Mini Bikes
post #1 of 14 (permalink) Old 02-26-2019 Thread Starter
Track Racer|Bike Builder
russpalmbones's Avatar
Help with Bike ID
Not the best photo but the seller claims it has a Polini WC engine. Looks like a Blata 2.6 to me? He is asking $700 which I know is too much but Any help would making ID would be great before I make the drive to look at it. Thanks
File Type: png Screenshot_20190226-153514_1551224274427.png (510.9 KB, 22 views)
russpalmbones is offline
post #2 of 14 (permalink) Old 02-26-2019
Re: Help with Bike ID
If its real it would be a Blata Elite10 series...Ask for them to take a pic of the top fork clamp and the pullstarter...
Top clamp should say Blata and the pullstarter Polini Motori
Pretty much worth the $700.00 if it is real..Retail was like $2800.00
post #3 of 14 (permalink) Old 02-26-2019 Thread Starter
Anything in particular to look for on the engine for wear? Do I need to check the fluid in the cooling system and belts/,pumps etc?
post #4 of 14 (permalink) Old 02-26-2019
Look in the overflow bottle.....If it looks gacked up like compression has been getting into the water it most likely has a bad head gasket..
Check the waterpump to see if its seized too..
Make sure it has compression..
Physically roll it around on the ground checking the brakes also making sure the neck bearings and clutch are good,,
A bike that looks that clean and is a current picture should fire up no problem if it was fully drained before being stored away..
Bring fuel..94/95 octane mixed to 50:1...They sell 94/95 octane in a can already mixed at either Lowes or home depot and sold by VP racing fuel;-Husqvarna too...
post #5 of 14 (permalink) Old 02-26-2019
Chrisi's Avatar
I think the elite 10 was only buildt with ac engine, should be an polini 6.2 ac 3 port cylinder.
I think its a elite 11
Chrisi is offline
post #6 of 14 (permalink) Old 03-01-2019
Elite 10 comes both watercooled and aircooled Im pretty sure seeings ive seen them both ways.
Blata Eite 11 has a more triangulated shaped swingarm and it cant be am Elite13 because that's a half fairing model...
post #7 of 14 (permalink) Old 04-02-2019 Thread Starter
I think I have a Blata Elite 11w does anyone know what years these we're produced? The Serial is CZ 07648 WE if that makes any sense. Im trying to figure out how old this thing is. Thanks
post #8 of 14 (permalink) Old 04-02-2019
Yeah..Youre right...We had a member here that bought a 10 that was liquid cooled but was a later model built bike that had the Blata Elite 11 engine on it....
The Elite 11 first came out in 1994...........
post #9 of 14 (permalink) Old 04-04-2019
what did i just buy?
I know its (probably) an Elite 13r?
what year?
Wouldpkr is offline
what year?
If its got the 14/14 SHA carb its an Elite 13A
If its got the PHVA carb its a 13R
Im pretty sure "UH" is 2005...
Welcome to the site and Good luck with the bike..
Yes, I believe its an E13, 40cc air cooled Blata, something like 36mm bore x 39mm stroke. probably a 14mm Dell 'Orto SHA carb.
Yep, its got an SHA. Thanks guys!
Wouldpkr is offline
Your bike is a 2005 model Elite 13A..
For some odd reason Rasto isnt responding so I contacted Blata in the UK and unfortunately theyve only been so much of a help...
Heres a copy of the email I got from them.Hopefully Rasto responds...
Radim Rozek Bc. <[email protected]>
Apr 9, 2019, 7:46 AM (4 days ago)
Hi,
Old bikes cant find manuals in English so Czech may have to do. Hopefully will help see enclosure and let me know if you need anything else. The SHA carbie was generally used on the 3 port engines but its possible to have on a 5 port air or water cooled cylinder as you can see on the Elite 13 engine jpeg. SHA carbie has part number 120.002.00.
Cool!
Thanks for the info Cam!
Im waiting on a gas tank to show up soon.
Ill probably drop the engine and have a closer look at it. I cant find any numbers on it at the moment.
Wouldpkr is offline
Pocket Bike Expert Needed-ID This Bike Pocketdirtbike Tuner General Pocketbike Discussion 4 04-21-2011 11:17 PM
Help: Need to ID a Bike. Raider357 Chat 4 11-18-2005 05:05 PM
Help: Trying to ID A Bike Raider357 4Stroke Midbikes 9 11-08-2005 07:35 PM
How do i ID this bike and help on Adjusting the clutch DqP European Pocketbikes 8 11-15-2004 11:17 PM
Help with Bike ID Antagonist 2Stroke Midbikes 12 10-04-2004 07:51 PM
