40cc 4 stroke pocket bike - Pocket Bike Forum - Mini Bikes
post #1 of 4 (permalink) Old 05-03-2019 Thread Starter
silverbullitt7's Avatar
I'm just curious, has anybody owned any of these brand new bone stock? I'm really curious on the top speed. I know there are adjustable, I've had a couple of these and 18 miles an hour was all I could hit. I know these are the Chinese Honda clone four strokes. Just looking for some real specs from someone who has owned these. Thanks
silverbullitt7 is offline
post #2 of 4 (permalink) Old 05-04-2019
Re: 40cc 4 stroke pocket bike
18mph is about right..They max out at 20mph..Theyre pretty restricted and are built for powertools so theyre quite deficient under load of a rider...
Wanna hit 20 try putting a lil trans fluid in the gas..it'll cool the intake valve and lubricate the topend plus will boost the compression by increasing ring seal alil giving the engine a lil extra punch
Theres mods to make them faster like uncork the exhaust by fabricating a headder put a 15mm carb in place of the 10mm carb or putting a carb from a Z50 Honda minitrail on it,ignition advance key,regrinding the camlobe,opening the intake / exhaust port hole,increasing the compression to 10.5 -11:1 ,lapping also readjusting the valves and tuning it in...
post #3 of 4 (permalink) Old 07-03-2019
i have one of these if you need to know, im about 200 to 220 on this thing and i think about 18 to 25 moh would be a fair to say.
mtxaudio1435 is offline
post #4 of 4 (permalink) Old 07-04-2019
draining out the factory oil and replacing it with good oil is the single most important thing on the 40cc 4 strokes
when you undo the drain plug onley half of the oil will come out to get it all out you need to blow air into the crank case where you fill it with a peace of vinyl tubing and your mouth. dont use a air compresser or it will blow out the seals.
i put 10w 30 synthetic in my neighbors the performance increase is noticeable
MrKitty is online now
What about that 40cc 4 stroke CC MOMO General Pocketbike Discussion 61 04-09-2018 03:11 PM
New 40cc 4 Stroke PB Engine EPR Air Cooled Pocketbikes 53 04-01-2016 07:02 PM
What performance mods can you do to 4 stroke 40cc pocket bike to go faster? Jtemp95 New to PocketBikePlanet? Start Here With an Introduction. 22 12-13-2015 11:26 PM
??? MPR has 40cc 4 stroke Cags-Blades EPR General Pocketbike Discussion 0 10-12-2014 04:34 PM
40cc 3port from a 40cc 5port?? all motor cag racer European Pocketbikes 4 12-27-2005 01:10 AM
