pocket bike triple tree for my sidecar - Pocket Bike Forum - Mini Bikes
post #1 of 5 (permalink) Old 09-04-2019 Thread Starter
i have a pocketbike sidecar that i need a new triple tree for. the only triple trees i see are for 22 mm forks or just wrong size. my triples have 25mm tubes and about 6 3/16 on center. not one pocket bike suplier sells this size. i wouldnt mind buying a complete fork and triple set with brakes. i can use all the help thanks.
shonnchango is offline
post #2 of 5 (permalink) Old 09-04-2019 Thread Starter
Here are some pics of my pocket bike
post #3 of 5 (permalink) Old 09-04-2019
Re: pocket bike triple tree for my sidecar
Welcome to the site.....Sidecar racers are pretty cool......Is yours complete?
All of my cags have 22mm forks except 2 and both had totally different type of fork clamps/neck tubes..
Anyways these claim to be the 25mm fork clamps you seek..It seems the 47cc DB-49 pocketdirtbikes have 25mm forktubes...
Description:
- 100% Brand New Front Fork Triple Tree Clamp
- Hole Diameter: 25mm/ 1 inch
- High class quality alloy, solid and durable
- Easy to install, no installation instructions
- Fitment: for 49cc Mini Pocket Dirt Quad Bike
https://www.amazon.com/TC-Motor-Trip.../dp/B07CZDRLZT
https://www.aliexpress.com/item/4000035751965.html
post #4 of 5 (permalink) Old 09-05-2019 Thread Starter
Thanks for the help but none of those will work. The tube size is corect but the spacing is way small.. I need 6 3/16 spacing on center those are more like 5 inches on center.
post #5 of 5 (permalink) Old 09-12-2019
You can adj. the distance between the triple clamp to fit the frame neck height. I put a 28mm C1, MT-A4 fork set up on a custom frame Cag with dual front brakes., and Cateye forks on a electric Razor frame.
File Type: jpg Razor Frame and Cateye Front Forks 1.jpg (464.4 KB, 4 views)
