help with exhaust plz - Pocket Bike Forum - Mini Bikes
 7Likes
post #1 of 80 (permalink) Old 09-17-2019 Thread Starter
my after market exhaust bolts constantly rattle loose, i had to rethread bolt holes on motor and i think when i rethreaded it i weakened it.
jdignan is offline
post #2 of 80 (permalink) Old 09-17-2019
did you try lock tight ???
post #3 of 80 (permalink) Old 09-17-2019 Thread Starter
would that work, lock tight only goes to 450
jdignan is offline
post #4 of 80 (permalink) Old 09-17-2019
Re: help with exhaust plz
There might be a high temp thread sealer. I wonder if Teflon thread tape would work.
post #5 of 80 (permalink) Old 09-18-2019
Most small Chinese engines use a flange system to where you can drill the threads out and use longer bolts and back it all up with plain old hex nuts....
On some cylinders you can use a file to modify the flange to fit a nut....
Sometimes the nuts or even the washers only have to be modified with a file but it's better than rattling loose..
That's what I do .......
post #6 of 80 (permalink) Old 09-18-2019 Thread Starter
ill look and see if i got that flange i just dont want to drill through anything important
jdignan is offline
post #7 of 80 (permalink) Old 09-18-2019
can you send us some pictures ???
post #8 of 80 (permalink) Old 09-18-2019 Thread Starter
ill send pics, do i need some kind of spring type support for muffler and the vibration?
jdignan is offline
post #9 of 80 (permalink) Old 09-18-2019
somewhere near the back of the pipe it needs to be mounted to something solid to keep the vibration down.
post #10 of 80 (permalink) Old 09-18-2019 Thread Starter
here is the pictures, that is the gasket i bought, and the support for exhaust and where i want to put it
File Type: jpg 15688545937531686254695290030009_1568854628725.jpg (354.2 KB, 8 views)
File Type: jpg 15688548530048030421788204947132_1568854867669.jpg (485.1 KB, 8 views)
jdignan is offline
dammmm man... thats ... so its time to tap and high heat epoxy studs in there then you need to grind that flange flat where the nuts will sit when you cinch it down i recommend 1 two finger ogga dooga or about 10 to 12 inch lbs with some lock tight
post #12 of 80 (permalink) Old 09-18-2019 Thread Starter
this for gasket delete, this for glueing exhaust bolts and whats (1 two finger ogga dooga or about 10 to 12 inch lbs with some lock tight)
File Type: jpg Screenshot_20190918-201712_Samsung Internet_1568863232105.jpg (82.6 KB, 2 views)
File Type: jpg Screenshot_20190918-202302_Samsung Internet_1568863470519.jpg (353.1 KB, 1 views)
jdignan is offline
where did you get it ? thats a bike exhaust flange (and system) its just a tiny bit to small to fit that engine on the flang and well.... your going to need to fix that befor you do anything.... way to restrictive for that engine
Chrisi's Avatar
Take two helicoil and repair the threads, then insert two bolts, no screws. And you should make you an holder for the exhaust, when the exhaust isn't fixed to the frame, then there is always the whole weight on the two screws.
Chrisi is offline
post #15 of 80 (permalink) Old 09-19-2019 Thread Starter
my exhaust is for bikes?
jdignan is offline
to do helicoils wiuld require him to drill and tap to the next size....
Why wouldnt he just use a larger bolt with a round socket head and save making a bunch of slinkys out of a package of heli-coils...?
you have a motorized bike setup... this is why the flange wont line up and the header tube size is smaller then the exhaust port on your engine ...
The poorly designed bicycle engine needs a lot of back pressure to hold the mix in the cylinder so it can run ( if that's what you want to call it more like sputtering across town)
50 / 80cc Bike Gas Engine Motor Parts - Voodoo Pipe Exhaust Muffler Black
https://www.ebay.com/p/50-80cc-Bike-...EaAsk4EALw_wcB
He would get way better performance gutting and reinstalling the box muffler than using that waste of $$$
exhaust pipe...
exhaust pipe...
This is the HP pipe he needs..
UberScoot 2x/Rx Performance Pipe
Here's the box type too...
https://www.ebay.com/itm/ScooterX-Ex...-/331116236407
i agree gutting the stock box and a tune will give him the most performance out of basicly any other options.
i love the add for that pipe saying it gives 3000 RPM increase ROTFLMAO they must be takeing notes from the china car audio manufacturers where you just add a zero to the real numbers try 300 RPM maybe on a good day 200$ for that trash wow...
the aftermarket box type is cool i bet $ the internal dimensions are the same as the stock muff box with the baffle removed so your paying 100$ for bling
