Bead on tyre won’t seal. - Pocket Bike Forum - Mini Bikes
 1Likes
  • 1 Post By CAM2
post #1 of 7 (permalink) Old 6 Days Ago Thread Starter
Tonck1's Avatar
I got a brand new MT-A4 out the box and I can’t get the rear tyre to hold air. It’s leaking from the rim. Last night took it to a tyre shop and got them to blast it with their co press or hoping it would pop. Put 40psi in it but still this morning, it’s flat again. Any suggestions?
Tonck1 is offline
post #2 of 7 (permalink) Old 6 Days Ago
It might be the rim or the tire is more then likley dry rotten from the inside out 15 year old China rubber you should consider replacing both tires for safety
post #3 of 7 (permalink) Old 6 Days Ago
Re: Bead on tyre wonít seal.
Originally Posted by Tonck1 View Post
I got a brand new MT-A4 out the box and I canít get the rear tyre to hold air. Itís leaking from the rim. Last night took it to a tyre shop and got them to blast it with their co press or hoping it would pop. Put 40psi in it but still this morning, itís flat again. Any suggestions?
Put an inner tube in it or buy better tires.....Chinese rubber is some porous material..
Even the larger Nitrogen molecules passes through with relative ease...ÖÖ.
One time I took a tube of GE silicone and some Bounty paper towels and I spread a thin layer of clear silicone on the inside of two cag tires and also on the tire beads which worked quite well...ÖÖ...
Theres a member named minipilot who has better quality PMT brand racing slicks 4sale too..
MiniPilot likes this.
post #4 of 7 (permalink) Old 6 Days Ago
MiniPilot's Avatar
Even the larger Nitrogen molecules passes through with relative ease...…….
One time I took a tube of GE silicone and some Bounty paper towels and I spread a thin layer of clear silicone on the inside of two cag tires and also on the tire beads which worked quite well...……...
Thank you for the mention, Cam2, I appreciate it.
MiniPilot is offline
post #5 of 7 (permalink) Old 6 Days Ago
You need a inner tube, I have put tubes in most of my China tires. My GRC-GP1 and Banshee Sho have euro tires, been a year with very air loss.
EPR is online now
post #6 of 7 (permalink) Old 5 Days Ago Thread Starter
Tonck1's Avatar
Thanks lads, will try an inner tube on it. Will replace both for decent slicks in time.
Tonck1 is offline
post #7 of 7 (permalink) Old 5 Days Ago
On tubeless tie a rope around the outside of the tire and pull in, forcing the beads to hit the rim. Even when changing tires I spray both beads w/ Windex spray glass cleaner to make the beads slippery. Tubes work very well, and keeps your tire from popping when there is no tread left.
EPR is online now
