How-To: Repairing Your Pullstart - Page 2 - Pocket Bike Forum - Mini Bikes
Re: How-To: Repairing Your Pullstart
Check to see if your spark plugs is firing with it off and the wire on and plug grounded to the engine, and or new plug NGK BM7A. Need to spin the flywheel fast for a good spark. If you get a spark, put a little gas down the carb and try to start it. If the bike sat for awhile I would clean the carb float bowl and main jet and atomizer tube.
Hey I just got an Aoli 39 or 40 cc aircooled think it might be c1 blata rep but does anyone know how to recoil the pull start on them
Jonesy.bullettz is offline
You have a 39cc China Blata clone, or C1 or MT-A4. Is it air or water cooled?? I have both but my C1 is the 50cc version.
The starter pulley has a spring that retracts the rope, if it breaks not going to work right. A new starter housing can be found for as little as $20. If the rope is bad, I use #6 chainsaw starter rope, you can rewind the pulley while still together if your slick.
Unless the spring comes undone from the spool when the rope snaps you never have to take the pullstarter apart to install the new pullrope...
Seeings like it sounds like the advice is a moot point but info none the less you must get the spring wound back up tightly then put back into the pullstarter housing then try to guide the j bend on the spring into the spool then reattach with the bolt...
The spool gets spun tight then hole in spool lines up with the hole in the pullstarter,,the rope is fed into the pullstarter hole and fished out through the spool pulled about 5" knot tied then rope pulled tightly then spool then letgo of spool to wind the rope up......
If the rope is too long after it retracts it can be adjusted /shortened through the handle side...Good luck
You see the flywheel photo, and the water pump pulley in front driven off a pulley on the back side of it with a rubber 0 ring belt, make sure the belt is on and the pump is turning before you start it, and never start it without fluid in the engine. Take the carb and intake off and look in the back of the engine to see if water leak into the engine.
post #26 of 31 (permalink) Old 4 Weeks Ago
its a aircooled version
post #27 of 31 (permalink) Old 4 Weeks Ago
I love the air cooled engine, I just built a brand new one last week from all new parts. My A/C engine is in a water cooled frame, it was a project bike I got from Boosted306, well known here but he retired from making modified parts and engines. Mine has the first type with two ring piston, now they use the same 37mm one ring piston same as the 39cc W/C engine. The 39cc A/C and 39cc & 50cc W/C all use the same crank and cases. No water pump for the A/C engine. The has a 37mm bore and 37mm stroke, which is what a call a square stroke engine, great revving engine. Can't find cyld and head for the A/C and same for the 50cc 39.5mm bore W/C.
post #28 of 31 (permalink) Old 3 Weeks Ago
Hey man I se you know a lot about pocket mini bikes ! I just bought my son a used one but it actually doesn't have a pull start on it I guess it broke off the guy I bought it from said he would just hook a battery up to it and jump start it and ride with the battery in hand ? right now all I see is where the pull start is suppose to be a round opening with like some sort of copper or electrical something going around a circle ? I have photos but I can't upload them .my number is 610-533-2985 I would pay you thru PayPal if you can maybe call me and tel me who I need to do ? if you have time if not I understand totally .thanks for your Time my name is gino in case you decide to call. thanks
ggeegino is offline
post #29 of 31 (permalink) Old 3 Weeks Ago
Can someone tell me what I would need to repair my pocket bike ? 2004 callager 49cc
ggeegino is offline
post #30 of 31 (permalink) Old 3 Weeks Ago
You need a starter pawl and starter housing w/ pull rope. There are 2 major types, one with a round steel starter pawl and one with alum rectangle pawl w/ paddle. Not sure which one you need. CAM2 is the guy you need to talk too. here are some photos, these are pull start only engines, yours is electric start, and the pull start hooks to the end of the of it.
post #31 of 31 (permalink) Old 3 Weeks Ago
Thanks so much for that info I will buy the parts and let you know how I did !
ggeegino is offline
