Engine stall when weight applied - Pocket Bike Forum - Mini Bikes
post #1 of 2 (permalink) Old 06-15-2019 Thread Starter
Hello all.
Looking for some suggestions on an issue im having with my 49 CC 2 stroke engine pocket bike.
Idles fine and goes with full throttle as long as their is no weight on the bike (I prop the bike up to test it)
it will run at full throttle no issues.
However if theres any weight applied even if i just sligthly lean on the bike with full throttle cuts out every time.
I put on a brand new carb, cleaned out the exhaust and it has fresh pre-mixed gas/oil.
any ideas what else it could be?
Thanks
Gavin Daly is offline
post #2 of 2 (permalink) Old 06-15-2019
Re: Engine stall when weight applied
Originally Posted by Gavin Daly View Post
Hello all.
Thanks
Welcome to the forum.....
Sounds like a coil thats going bad or an airleak,,,maybe weak compression /bad reeds too
Have you tried checking the airgap between the coil and the flywheel making sure its tight and at at .020" airgap or even putting a new sparkplug first?
Pull the current sparkplug out and post a pic of its condition when its removed.............
NGK brand BM6A for reed inducted 2 strokers BPM6A for piston ported
Heres a link to a thread that shows how to post pics on the site pretty easily.....
https://www.pocketbikeplanet.com/170...learn-how.html
