Hi all new to the forum - Page 2 - Pocket Bike Forum - Mini Bikes
post #21 of 30 (permalink) Old 4 Weeks Ago
Re: Hi all new to the forum
Originally Posted by Steve2020 View Post
Heres the bike and quad I have
Looks like a Chinese made mini King Quad 49cc 2 stroker with electric start and headlight...
Like this model....
11 and 72 would be 6.6:1 ratio plus you need to add in the transmission reduction too..You need 12-13:1 ratio for a 1.9hp miniquad for a rider over 80lbs..Just don't expect more than 11mph fully topped out also...
Judging by the sprocket on the transmission you need a Tf-8mm chain
If you can't get the ratio any higher due to size limitations you need to use a clutch Bell with a 6tth Tf-8mm pinion then realign the rear sprocket or mod the engine closer to 4hp....
post #22 of 30 (permalink) Old 4 Weeks Ago
With the 3 to 1 trans and if you had 11/72 sprockets you would have about 9.6 to 1, still a little high for you, with a 78 you would have 10.09 to 1. If you could find an 80 plus tooth rear you might get 10.5
post #23 of 30 (permalink) Old 3 Weeks Ago Thread Starter
Thanks all
Hope you had a good Christmas
Been looking around and seems like i need 8mm setup. How do I double check this? If I measure chain link pin to chain link pin will that give me the size?
Largest 8mm rear sprocket seems to be 74 and smallest front for the quads transmission 11
Thanks
Steve2020 is offline
post #24 of 30 (permalink) Old 3 Weeks Ago
Yep. 8mm pin to pin. Same as 5/16. Should be 3/16 between the inner plates as well.
pntrbl is offline
post #25 of 30 (permalink) Old 3 Weeks Ago
8mm is much bigger chain than #25 Cag chain, 25 has about 750lbs strength and 8mm 1200lbs, used a lot with scooters and piston port engines and trans.
post #26 of 30 (permalink) Old 3 Weeks Ago Thread Starter
Aahhh yes just squeezed into the shed and held the chain next to the mini bike.. The quads chain is definitely bigger... Pics attached
So guessing 6mm on bike and 8mm on quad
Thanks
post #27 of 30 (permalink) Old 3 Weeks Ago
Thanks
Yes theres a #25 on the minibike and a TF-8mm on the miniquad.
Just know if you buy another TF-8mm pinion and rear sprocket you can make the pocketbike TF-8mm or the pocketdirtquad to #25 to keep both chainsets the same too.
Theres 3 different types of drive chains they use on pocketbikes , pocket dirtbikes and pocket quads.…Technically theres actually 4..
#25 is like linguini, There s nothing smaller for these pocketbikes
25h is slightly beefier as H stands for Heavy Duty..The first pic shows a 25h.
TF-8MM which looks exactly like the oval shapes of the chainlinks on a timing chain.
#410 which looks exactly like a bicycle chain just slightly wider...…
#410 chain is also used for chaindrive garage door openers..
Theres a parafin wax and oil treatment you can do with some heat inside a metal can that's done to new chains to properly pre-lube to protect the chain from initial damage to the link rollers when initially used.
Im sure theres like 1000 vids on utube on the process that can be researched...Its actually very easy..
Another point to touch upon is whether to use or not to use a masterlink….
I say buy a chainbreaker tool that can do both types of chain and mend both chains without a masterlink…...Theres nothing like losing the link and having to carry or push something so small home.....
post #28 of 30 (permalink) Old 2 Weeks Ago Thread Starter
Got my new front and rear sprocket just need the chain now and to modify the rear mud guard mount and chain guard mount as the new sprocket touches them.. ... Old sprocket is on top
post #29 of 30 (permalink) Old 2 Weeks Ago
It will be pretty torquey now......
post #30 of 30 (permalink) Old 2 Weeks Ago
Way to go Steve. You will see a big difference in your low end.
