New to the game - Pocket Bike Forum - Mini Bikes
post #1 of 34 (permalink) Old 4 Weeks Ago Thread Starter
Mack Mall's Avatar
New to the game
Hey I just brought 2 pocket bikes don't know what they are but I need help with the wires one of the clips is empty and I have no clue where it goes to I brought a electric start for it to my dispar it doesn't work please help
Mack Mall is offline
post #2 of 34 (permalink) Old 4 Weeks Ago
Re: New to the game
Welcome to the site...Pics of what you have helps a lot....
For the wiring issue look into a recent thread by nerdydaddyo…..He just posted a PDF he made....
Heres the link
https://www.pocketbikeplanet.com/170...cket-bike.html
post #3 of 34 (permalink) Old 4 Weeks Ago Thread Starter
Mack Mall's Avatar
How do I add pix
post #4 of 34 (permalink) Old 4 Weeks Ago Thread Starter
Mack Mall's Avatar
post #5 of 34 (permalink) Old 4 Weeks Ago Thread Starter
Mack Mall's Avatar
The clip where my thumb is not connected to anything
post #6 of 34 (permalink) Old 4 Weeks Ago Thread Starter
Mack Mall's Avatar
I have no clue to where it goes I've cut the wires and tried hooking it up to the battery to get the electric start to work but that didn't work the electric start in new the plug where the electric start was hook to a solenoid I took that off and put the electric start plug in and had that clip left empty
post #7 of 34 (permalink) Old 4 Weeks Ago
The starters fail they never last use jumper cables and connect it directly to test and see if it even works to start with
post #8 of 34 (permalink) Old 4 Weeks Ago
Re: New to the game
You have two FS-509 49cc Cateye midbikes with 2 stroke piston ported engines..
You need to pull the rear brake handle to disable the safety interlock and activate the starter before it can be triggered with the starter pushbutton...
To bypass the safety interlock cut the wire from the rear brake handle and simply twist them together...……..
First thing I'd do is find the fuse and replace the whole thing;- holder and all with a weatherproof ATC type as the Chinese fuse holders are highly problematic....
If the starter will still not trigger do a continuity test on the starter pushbutton as they oxidize and rust-up easily inside and can be disassembled to be cleaned-up too...
The plug you're pointing out may be a a battery charger plug as those bikes came with a very problematic and crappy 3 prong battery charger that overcharges the battery...……..
post #9 of 34 (permalink) Old 4 Weeks Ago Thread Starter
Mack Mall's Avatar
Good news I busted 5 fuses the 6 amp kind lol found out the that the white wire will engage the engine but the electric start won't even tho it's brand new. I cut the wire I indicated and touched it to the wrong wire an blew fuses I'm going to change the fuse to the to teeth fuse cause I can't find the 10 amp fuses here where I live I'll post pix of what I have done for more info to where the wires go
post #10 of 34 (permalink) Old 4 Weeks Ago Thread Starter
Mack Mall's Avatar
post #11 of 34 (permalink) Old 4 Weeks Ago Thread Starter
Mack Mall's Avatar
I posted the picture of my beautiful mess lol. I'm so lost I've been touching wires to see what happens I even pull the back and the front break lever when I try to start it to see if it will start. The red wire that isn't connected it will blow the fuse if I touch it to the positive the Yello wire makes a bussing sound when I connect it the positive the white wire that's wrapped up will try and start the bike when I touch it to the positive the blue wire i have no clue what it dose. What do I need to do to get it the bike working with the electric start
File Type: jpg IMG_20200125_010538186_1579932925823.jpg (440.8 KB, 3 views)
post #12 of 34 (permalink) Old 4 Weeks Ago Thread Starter
Mack Mall's Avatar
More pix of my beautiful mess
File Type: jpg IMG_20200125_010411563_1579933110757.jpg (427.8 KB, 4 views)
post #13 of 34 (permalink) Old 4 Weeks Ago Thread Starter
Mack Mall's Avatar
More pix of my mess in daylight don't know if I got it hooked up right or if I need a solenoid but the red blue and yellow wires are what's left
File Type: jpg IMG_20200125_125219673_1579974857819.jpg (483.4 KB, 4 views)
File Type: jpg IMG_20200125_125153557_1579974891213.jpg (486.2 KB, 3 views)
post #14 of 34 (permalink) Old 4 Weeks Ago
Re: New to the game
This is a Cateye wiring dia. Look at the blue wires
post #15 of 34 (permalink) Old 4 Weeks Ago
Re: New to the game
Heres an easy to follow and complete in under an hour to get the starter and charging system working then if desired can wire-in the lighting later..
That's basically the way I have this thing wired up except with the addition to a mini servo to push the pushbutton...
It has the same engine as on your cateye…..
This is my homemade R/C buggy made with bits n pieces from a Cateye and a miniquad attached to a custom-made steel frame..The ower to weight ratio of this thing is ridiculous when compared to the power to weight ratio of a $300k sports car and it costed me $280.00 and 28 days to build...……......lOL
Its just a bit more modified with almost 5x more HP...………
File Type: jpg Typical2strokestartandchargersystem_zps61f404f0.jpg (53.8 KB, 0 views)
post #16 of 34 (permalink) Old 4 Weeks Ago Thread Starter
Mack Mall's Avatar
Found out the push start I ordered wasn't strong enough to to start the bike now I need to know where the rest of the wires go and how to get my speedometer to work and charging port
File Type: jpg IMG_20200127_130223174_HDR_1580148164558.jpg (508.0 KB, 5 views)
post #17 of 34 (permalink) Old 4 Weeks Ago
Re: New to the game
Im pretty sure that would be the blue wire...…….It goes to a positive connection.
The yellow is the rectifier wire that goes on the screw terminal on the solenoid that goes to the starter motor as the starter motor doubles as a generator too......
post #18 of 34 (permalink) Old 4 Weeks Ago Thread Starter
Mack Mall's Avatar
Man you guys are really teaching me how to wire a bike the only wires left is a black wire with a wire stripe and a red wire but I wired the two red wires together how I don't blow another fuse only got 2 left
post #19 of 34 (permalink) Old 4 Weeks Ago Thread Starter
Mack Mall's Avatar
I brought a x8 today at least I think it is super cheap 75$ lady brought a storage container and it was in it and the coil is bad well they guy that's helping said it was I'm scared to order one from online cause the push start I ordered wasn't the same as in the picture but imma have to how can I tell if the coil I order will be the right one the coil has xg stamped on it the guy that's helping me doesn't no much but knows more than I do but you guys know more than both of us put together
File Type: jpg IMG_20200127_170048991_1580190896810.jpg (592.7 KB, 4 views)
post #20 of 34 (permalink) Old 4 Weeks Ago
bikefactory's Avatar
Re: New to the game
Thanks for valuable information here.
www.motoxindustries.com
bikefactory is offline
