Can’t get my X1 to start - Pocket Bike Forum - Mini Bikes
post #1 of 6 (permalink) Old 2 Weeks Ago Thread Starter
Hey guys. My dad bought a crappy X1 pocket bike a long time ago and eventually stopped riding it for like 6 years and the gas just went crap. I recently tried to fix it up doing the general stuff, cleaned the tank, new fuel lines, cleaned the carb etc. At first the pull start wasn’t pulling so I put some oil down the spark plug hole and it eventually started pulling. However whenever I put the spark plug back in and tighten it up the compression is so tight I can’t pull it at all. Any suggestions? I’m thinking I need to loosen the piston up as it probably has a decent amount of rust and gunked up gas over the years. The engine is getting fuel it’s just impossible to pull.
Kaiguy04 is offline
post #2 of 6 (permalink) Old 2 Weeks Ago
Re: Canít get my X1 to start
Welcome to the forum....
Sounds like you may need to gut the e-starter/generator combo to free things up
You may also need to de-rust the coil and magneto too...ÖÖ
If the coil and mag are rusty the airgap when reassembling is .020" sae
Heres a thread on how to achieve the e-starter gutting,,,
https://www.pocketbikeplanet.com/82-...ke-engine.html
post #3 of 6 (permalink) Old 2 Weeks Ago
I would look at the piston thru the intake or exhaust. I would pull the cyld off and look at the parts inside, you will know right away if there is a problem. Take the 4 allen/socket bolts off at the base and pull it off. A new cyld, piston & rings rod pin, bearing set is less than $30
post #4 of 6 (permalink) Old 2 Weeks Ago
Yep and don't forget from his description he will need to replace the crank seals too...Ö..
Years back while chasing after one of my dogs that was chasing after a female dog I ran across a 33cc scooter submerged in the creek.....
After catching the bugger I went back and fished it out...
It looked grim but with some silicone spray,trans fluid,old coil from an x1 and a 10mm replacement carb also some new crank seals the engine fired-up and ran pretty god so I disassembled it blueprinted and ported it and added a 15mm carb in place of the 10mm carb ,rocket key,lightened flywheel modified clutch , modified X1 revpipe exhaust, boost bottle plus borrowed the pullstarter off my twin engine mini harley and that lil thing was flying...Ö..
Even though this is a reed ported engineas you can see they rust-up pretty badly...
A lil clean-up , a coil and crankseal change plus carb replacement and it fired right up ...
post #5 of 6 (permalink) Old 2 Weeks Ago Thread Starter
Thanks for the suggestions everyone. Iíll do what you guys suggested and see if it fires up
Kaiguy04 is offline
post #6 of 6 (permalink) Old 2 Weeks Ago
For cold starting, after it sit for awhile, I have an eye dropper in a small glass jar, It's filled with 2 stroke gas. Use it even on my 4 strokes to start, cause it has that oil in it. I squirt a dropper full into the carb, then try to start it. If you have a spark and decent compression it should start or pop. After a couple of tries, and it don't start, pull the plug, is it wet, a sign the coil or spark plug are not working. put the wire back on and ground the plug nut to ground, pull the rope and look for a nice blue spark.
