Blata origami b2 broken clutch - Pocket Bike Forum - Mini Bikes
post #1 of 30 (permalink) Old 2 Weeks Ago Thread Starter
Prblatab2's Avatar
Hi guys of the forum i have a question if any one can help me to see what happends with my bike i run today amd everything was good after a few minutes of ride i see my bike only rpm amd dont have any power amd im see amd smell about the cluth and see was broken why this happen or whats the reason because i dont want to make same thing and broken again and where i can buy a new one
Prblatab2 is offline
post #2 of 30 (permalink) Old 2 Weeks Ago
Re: Blata origami b2 broken clutch
Sounds like you need to be more aggressive on the throttle....
You should always check the clutch adjustment after every 3-5 races and deglaze the pads n clutchbell each time....
If youre just riding it you better get a different bike for that if youre not gonna ride it like you're racing it as it is after-all "a racing machine"....
post #3 of 30 (permalink) Old 2 Weeks Ago Thread Starter
Prblatab2's Avatar
Hi cam2 and yeah i was driving in the kart track the bike and was really fast running good one friend in the kart track told me i was push to much to the accelerated amd thats why I broken the pad clutch
post #4 of 30 (permalink) Old 2 Weeks Ago
I would talk to member Chrisi, he can sell you a good used or new clutch. My supplier is out of business as many are too. Its nearly dead her in America. You might be able to use a C1 clone Blata clutch $20. A real clutch is $200 to $300, you can buy replacement arms and put them on your backing plate w/ new springs.
post #5 of 30 (permalink) Old 2 Weeks Ago Thread Starter
Prblatab2's Avatar
This is how looks
File Type: jpg 1C75902A-C32A-40CA-B334-64A4028D05F6_1584939125236.jpg (502.9 KB, 8 views)
File Type: jpg E1B80C56-1924-4A32-9183-3172BE9DED36_1584940785794.jpg (333.6 KB, 8 views)
post #6 of 30 (permalink) Old 2 Weeks Ago
Chrisi's Avatar
This is how looks
First of all, this is not a original Blata clutch pad, it's "made in China".
Original Blata pads have the name on it and there are 3 different pads available.
"normal" pad, "kit" pad and w50 pad. I've ad a Pic for example.
But it's also possible that your transmission setup was to long for an indoor track, it's better to be to short than to long. Also a high quality clutch like Zocchi, Blata or BZM will burn down when the transmission setup and the clutch setup is wrong.
The clutchbell you can give on a mille to clean it out.
File Type: jpg 15849473546751867525215058175404_1584947361924.jpg (469.4 KB, 5 views)
Chrisi is online now
post #7 of 30 (permalink) Old 2 Weeks Ago Thread Starter
Prblatab2's Avatar
Hi chrisi and yes the guy who sell me the bike he said he already change the clutch and yes i was in a long track when this happend me
So do you think i can remplace the clutch with a replica one or is better to put the original amd order from uk
post #8 of 30 (permalink) Old 2 Weeks Ago Thread Starter
Prblatab2's Avatar
Also chris what do you mean to mille to clean it out the drum clutch bell or how i can clean it out also thank you for your help
post #9 of 30 (permalink) Old 2 Weeks Ago
Chrisi's Avatar
Sorry for the bad english😅
Put the bell on a lathe( think that's the correct word).
You can also use sandpaper but it works better on a lathe.
Where are you from?
post #10 of 30 (permalink) Old 2 Weeks Ago
If youre racing I suggest you belly up and buy atleast 5 premium clutches in one batch...In racing clutches are the second biggest expense next to topend rebuilds so I hope your keeping tabs on hours and doing compression aswell as leakdown tests at intervals suggested by Blata techs.....Youre gonna need every one of those clutches and after those burn up you can buy new springs and kevlar material also high heat epoxy to reline your old clutch arms and have plenty of back-ups on hand ......
I don't even want to begin to fathom all the clutches Ive burnt out with all the toys I have or the amount of times Ive pulled a bellhousing and sanded a drum with 100 grit in a zig zag pattern ...LOL
post #11 of 30 (permalink) Old 2 Weeks Ago Thread Starter
Prblatab2's Avatar
Thank you chrisi for the info amd im from usa
post #12 of 30 (permalink) Old 2 Weeks Ago Thread Starter
Prblatab2's Avatar
Thank you so much cam2 I appreciate your help and yeah im think im buy a few clutchs because i dont want to burn again also yeah im think im clean the drum bell with a sand paper because is more cheaper here and i dont have any machine to clean it up and the drum bell is really expensive so is better if i clean it out
post #13 of 30 (permalink) Old 2 Weeks Ago
Chrisi's Avatar
No problem👍🏻
I have a used original Blata clutch on stock and some others like Zocchi, BZM and cs racing if interested.
post #14 of 30 (permalink) Old 2 Weeks Ago Thread Starter
Prblatab2's Avatar
Nice chrisi and how much do you looking to get
pm if you want
post #15 of 30 (permalink) Old 2 Weeks Ago
Go Chrisi, man. a China clutch on a Euro engine, that's a big disaster to start with. You need Kevlar pads if you racing on a track. Is the clutch housing Chinese or Blata?? You might need a different gearing, smaller pinion or larger rear gear so on a short track you don't burn up the clutch pads especially China pads, I see another problem I see, The Blata has a 80mm bell and the C1 has a 78mm bell, if that is true you have 2mm clearing when you need 1mm. That's another reason your clutch pads wear out fast, Your C1 clutch is 2mm smaller the a Blata clutch, way to much space. If your going to use them clutches you need to fit a China clutch housing. If your clutch plate is Blata I would look for re-done arms. I put a Polini housing and clutch on my 39cc polini clone engine with just a few simple mods, works very Good. I have a 79mm BZM bell here for worn clutches, I put a new billet 80mm bell clutch housing on my 690 cases on my 40cc BMZ engine.
File Type: jpg BZM 2 Shoe Clutch and Polini Housing on GRC1.jpg (510.0 KB, 6 views)
post #16 of 30 (permalink) Old 2 Weeks Ago Thread Starter
Prblatab2's Avatar
Hi epr and yea the bell and everything is blata genuine the only china was the clutch pads but everything else is authentic
post #17 of 30 (permalink) Old 2 Weeks Ago
The guy you got it from did not know what he was doing. That's probably why he sold it, did not have the bucks for a real clutch. The winter before, the C1 was in my wood shed, I got it out in mid Spring. I started it, revved it and the engine came to a stop, locked up. When the new clutch sat all winter the crappy alum under the glue turned to powder, the pad came off and wedged in between another pad and arm.
The C1 clutch bell 78mm bell and 76mm OD clutch is to small for the 80mm Blata bell, the B clutch is 78mm. 1mm is the space between the pads and the bell, on a C1/B1 clutch in a Blata bell would have 2mm, way to much. Like that you would wear the pads in no time. If your engine is revving to high before they grip, you have to much space. My BZM has a 80mm bell, but I have a new spare 79mm so when the pads wear enough I put the smaller bell in the clutch housing.
Your clutches are slipping to much with that much space, they might grab to late, and if you back off at all they will slip.
post #18 of 30 (permalink) Old 2 Weeks Ago
Chrisi's Avatar
Clutches + price.
And the last picture how to remove the clutch without a removal tool, always turne one screw a little bit, then the next and so on.
File Type: jpg 15850696135226297621500365660642_1585069621464.jpg (283.1 KB, 9 views)
File Type: jpg 15850696392898327560566391832853_1585069648557.jpg (388.4 KB, 8 views)
File Type: jpg 15850696694867180486870549302119_1585069678426.jpg (354.1 KB, 9 views)
File Type: jpg 15850696977417023413349879012687_1585069707009.jpg (331.5 KB, 9 views)
File Type: jpg 15850698158951495385956419371245_1585069828677.jpg (420.4 KB, 9 views)
post #19 of 30 (permalink) Old 6 Days Ago Thread Starter
Prblatab2's Avatar
Question guys to turn on my bike i need to put a clutch or i cant start on just to warm the bike
Chrisi's Avatar
Don't need a clutch to start and run the bike.
