Flywheel with little movement - Pocket Bike Forum - Mini Bikes
post #1 of 9 (permalink) Old 2 Weeks Ago Thread Starter
I have a mini moto and it kept cutting out as soon as it started moving so i decided to clean the carb. I took the whole engine out but when ive put it back together the flywheel only turns so far and then no further. It moves back so far before again not moving. I put a little 2 stroke in the spark plug hole to try and loosen it but that hasnt worked. Any ideas??
dazgroves is offline
post #2 of 9 (permalink) Old 2 Weeks Ago
What engine do you have ? You should take the flywheel back off and see if it spins ok without the spark plug...
post #3 of 9 (permalink) Old 2 Weeks Ago Thread Starter
Its a 49cc engine. I will take the flywheel off and have a look. Maybe something came loose when i took the engine off and it was upside down?
post #4 of 9 (permalink) Old 2 Weeks Ago
49cc Reed inducted
Or 49cc Piston Ported
Those are two of the most common 49cc engines on China Pocket bikes at least...
post #5 of 9 (permalink) Old 2 Weeks Ago Thread Starter
49cc Reed inducted
Attachment 154031
Attachment 154033
Its similar to the top one. I have a clip of it not moving but dont know how to upload it!
post #6 of 9 (permalink) Old 2 Weeks Ago
You can upload the clip to like YouTube ( YouTube is obsolete) or TicTok then past the link here if it's the Reed inducted engine like the top one you may have installed the Reed cage upside down
post #7 of 9 (permalink) Old 2 Weeks Ago Thread Starter
Ive sorted it! I took the cylinder off and there was a tiny piece of metal in there which must have been stopping the piston turning. Removed it, put it all back together and its running!
post #8 of 9 (permalink) Old 2 Weeks Ago
Right on !!!! Dirt and debri foreign or non foreign objects whether it's flashing a little bit of screw or some metal from a ball bearing is the number one cause of catastrophic engine failure!!!
post #9 of 9 (permalink) Old 2 Weeks Ago
Chrisi's Avatar
You should disassemble a little more than just the cylinder, where did the metal piece come from?
If a bearing breaks and crumbles, you can throw the motor away.
Chrisi is offline
