X1 Clutch Question - Pocket Bike Forum - Mini Bikes
post #1 of 14 (permalink) Old 04-10-2019 Thread Starter
X1 Clutch Question
I have an X1 that the clutch was slipping on. I ordered a new clutch for my son to put in and noticed that there was a regular flat washer on only one bolt on the backside of the clutch shoes between the shoes and the the flywheel. Is he missing missing a washer on the other bolt? Should there even be anything between the shoes and flywheel? Do I need to order a bolt kit now? Also, the shoes didn’t look bad on the clutch he pulled out. Maybe it was just glazed and slipping?
Louis is offline
post #2 of 14 (permalink) Old 04-10-2019
Re: X1 Clutch Question
Originally Posted by Louis View Post
I have an X1 that the clutch was slipping on. I ordered a new clutch for my son to put in and noticed that there was a regular flat washer on only one bolt on the backside of the clutch shoes between the shoes and the the flywheel. Is he missing missing a washer on the other bolt? Should there even be anything between the shoes and flywheel? Do I need to order a bolt kit now? Also, the shoes didnít look bad on the clutch he pulled out. Maybe it was just glazed and slipping?
Its possible the clutch was slipping from the pads and the drum being glazed as its very common..
The new pads will reglaze just as fast if you dont use 100 grit to get rid of the build-up and roughen the drum..
Another thing that causes pads to glaze it is oxidation and rust that hinders the throw-out of the clutch arms that accumulates on the shoulder bolts and in the pad mount holes//..A novice rider that blips the throttle is another culprit to glazing the clutchpads and clutch drum..With these bikes you basically gotta stab the throttle, hold-on and go ;- Not feathering or blipping the throttle on takeoff or when riding no matter how cool it sounds and feels...
The flat washers behind the pads are needed and the wavy washers on the outside under the hex head arent needed..You don't want the clutch arms touching the flywheel or sitting in the clutch drum slightly askew...
post #3 of 14 (permalink) Old 04-11-2019 Thread Starter
Can I just go to the hardware store and match up with washer or are they special sizes? Should I put some anti-seize on the bolt shoulders and how tight do I make the bolts when installing new clutch?
Louis is offline
post #4 of 14 (permalink) Old 04-11-2019
Yes you can buy a wsher from the hardware store...Check the magneto for the lost washer...ÖÖ.
Yes anti-seize is good to use;-so is using loctite on the threads..
Bolt torque is like 10 in/lbs......
post #5 of 14 (permalink) Old 04-11-2019 Thread Starter
Thanks. How do I check magneto? Red or blue loctite? You also opened up the gearbox while I had it off and there is a very small chain around 2 sprockets inside and chain was very saggy. Normal? Also noticed a lot of thick built up grease inside
Louis is offline
post #6 of 14 (permalink) Old 04-11-2019
I've wondered about that sloppy primary chain myself, but yeah, that's the way they are.
pntrbl is offline
post #7 of 14 (permalink) Old 04-11-2019
Just look for the lost washer to be stuck to the magnets or the back of the flywheel or if he didn't remove the fancover look in the bottom of the fancase in which of it is in there you want to get it out of there before it causes a problem....Its steel and the magnets are strong..
I like the green loctite but if you have red and blue definately red...
Saggy chain is pretty normal aslong as the top isnt touching the bottom....
The chinese put food safe vegetable grease in them as EPA safe lubricant just in case the cargo ship sinks theres no real envirnonmental impact from possible pollution of petroleum based products..........
If you go the liquid lube route prepare for the lube to escape the lil vent hole while riding and you will have to frequently check n fill it or you can use silicone grease which is nice n sticky and will stay on the chain longer than regular grease.......
post #8 of 14 (permalink) Old 04-11-2019 Thread Starter
How do you remove the flywheel? I can’t even see the magneto right now.
Louis is offline
post #9 of 14 (permalink) Old 04-11-2019
How do you remove the flywheel? I canít even see the magneto right now.
You take the 4 fancase screws out to remove the outer cover then you remove the center flywheel nut using a 1/4" cordless impact driver with a 12mm socket then use a steeringwheel puller tool to remove the flywheel from the crankshaft...
https://www.autozone.com/loan-a-tool...set/555516_0_0
I would do the flywheel mod and the rocket key since youve gone this far..Maybe even a boost bottle setup..
Those engines are 43cc and 1.6hp and need all the help they can get..............
post #10 of 14 (permalink) Old 04-11-2019 Thread Starter
I’m not familiar with any of these mods? My clutch only has a single spring in the middle too
Louis is offline
Iím not familiar with any of these mods? My clutch only has a single spring in the middle too
Yeah this is the one youre seeing,,,,same exact technique to removing the fancase cover and the flywheel... ..
post #12 of 14 (permalink) Old 04-11-2019 Thread Starter
I just removed the fan case and found the washer in there. Thank you
Louis is offline
Thats where it usually falls...LOL
You're Welcome.
You can buy an hp spring for your clutch online, it makes the engine revv higher before the pads engauge, giving you more take off power. Lightening the clutch arms helps with that also, same fore the flywheel etc., or any moving parts.
Total bike weight is your biggest enemy for take off and top speed.
EPR is online now
x1 x1 body KellyG General Pocketbike Discussion 0 12-03-2010 03:16 PM
X1 Gas to The Gears of War X1 Electric!!!!! j.blackeagle Electric Pocketbikes 2 03-12-2009 12:25 AM
X1 in processand please... !! if u have a X1 read the end! wolfhowler529 Pocketbike Paint and Design 22 05-26-2008 01:12 PM
X1 in processand please... !! if u have a X1 read the end! wolfhowler529 Pocketbike Paint and Design 0 03-22-2008 11:53 AM
X1 clutch drum question 97slowbird Midbikes / Superbikes 0 06-26-2007 06:44 AM
