help with predator 212cc motor - Pocket Bike Forum - Mini Bikes
post #1 of 26 (permalink) Old 09-11-2019 Thread Starter
hey all, i wanted to change out my 50cc uberscoot stock motor for predator 212cc, can i leave the 2 speed gearbox on or does it need new tranamission, i wanted to go hopefully 40mph with scooter and 212cc, i weigh 264...any info is appreciated
jdignan is offline
post #2 of 26 (permalink) Old 09-11-2019
I've had good luck with polini and blata engines. Definitely in the 40 to 50 mph range with stock transmission. I think it would be nearly impossible to mount the predator to the transmission.
JIMMY310 is offline
post #3 of 26 (permalink) Old 09-12-2019 Thread Starter
but would predator work then going 40mph without transmission?
jdignan is offline
post #4 of 26 (permalink) Old 09-12-2019
that polini puts out way more power and RPM then a predator...
you might as well do that swap...
MrKitty is online now
post #5 of 26 (permalink) Old 09-12-2019
Re: help with predator 212cc motor
Do you have a death wish?? The 212cc is way to heavy for your scooter and the low end torque will flip over on you, or you to lose control. In Calif. the top speed is 30 MPH to stay legal.
post #6 of 26 (permalink) Old 09-12-2019 Thread Starter
thanks for the info, i looked at polini engines but i think they are way over my budget, only price i saw online is 6000$ usd, thats why i was thinking the 212 predator because its 120$ and i can find upgrades easy
jdignan is offline
post #7 of 26 (permalink) Old 09-12-2019 Thread Starter
ok 212 is too big, i was thinking that it might be, what about 79cc predator and can i hook it up to gearbox or is it too much power for that
jdignan is offline
post #8 of 26 (permalink) Old 09-12-2019 Thread Starter
i dont live in cali anymore btw
jdignan is offline
post #9 of 26 (permalink) Old 09-12-2019
The problem is four strokes have torque and not rpm so you need a way to convert that torque into RPM with some kind of CVT or transmission gerd at the right ratio for the engine
You would probably be much better off modifying the engine you already have.
This is the 2 speed setup he needs but for an engine as big as the 6.5 or 7hp Predator he only needs to modify the engine to run without the governor and a Torque-a-verter and he will do 50-55 mph without a 2 speed transmission.........…............
One thing about putting such a heavy torque monster of an engine on a scooter frame...It wont be easy to control due to the weight of the engine is gonna be the culprit....
I tried putting a 5hp flattop on a GSMoon scooter....I turned it into a mini-minibike....LOL
If the OP would learn how to port and modify the engine he has he will be able to hit 40mph with what he has.........…
When this pic was taken my homemade stand-up scooter did 42-43mph with a modded 49cc engine and a CVT transmission.....
File Type: jpg 11526_10201846645306305_1444995576_n.jpg (29.2 KB, 2 views)
post #11 of 26 (permalink) Old 09-12-2019 Thread Starter
yeah i got upgraded exhaust and carb but cant use bore kit because discontinued motor is what i was told
File Type: jpg Screenshot_20190814-080013_Samsung Internet_1568338260418.jpg (95.7 KB, 2 views)
File Type: jpg Screenshot_20190814-080103_Drive_1568338311230.jpg (149.5 KB, 2 views)
jdignan is offline
you can do a base gasket delet mod to up the compershon port and blueprint the cylinder and crankcase lighten the flywheel turbo crank mod lighten the wrist pin add a rocket key and a boost bottle and that thing will crank out the sweet sound of stellar RPMs for basicly free...
if you want to spend some money you can put SKF bearings in the crankcase and try to find some Japanese crankcase seals for a genuine Honda brush cutter.
bolt on performance parts are not the way to go...
post #13 of 26 (permalink) Old 09-13-2019 Thread Starter
ok, i am new to this but will do mega research, already read some about gasket delete mod and it seems like i gotta do this carefully
jdignan is offline
its supper easy all you do is pull the cylinder off use some brake cleaner and a plastic razor blade (not the typical metal ones) and gently remove the old gasket remnants not leting any fall into the crank case then apply a micro thin layer of yamabond or hondabond to the jug and slide the cylinder back on well compersing the rings with your fingers to help them start tighten her up and enjoy free horsepower...
if you add a rocket key and boost bottle at the same time you will notace a big difference in performance...
File Type: jpg 51orZfsJY7L_1568352314265._AC_SY400_.jpg (30.4 KB, 3 views)
Only of you dont totally disassemble the engine to build it up........
You dont want gasket pieces getting in the crankcase or the crank bearings......
Its a lil more than just removing a gasket but it isnt overly hard if you follow and adhere to the laymans directions to modifying these types of engines or you will need to learn how to use a degree wheel...........
Just know that these engines were never intended for rideables and the extra loads exerted on them...Theyre backpack blower, auger , trashpump and brushcutter replacement engines adapted to be put on rideables....
The engine you have is a knockoff of real Mitsubishi brand 2 stroke engine...
If you do a proper search and read through the threads youll find plenty of information.....
Good luck
post #16 of 26 (permalink) Old 09-13-2019 Thread Starter
hey thanks, i just dont know what compersing the rings with your fingers mean
jdignan is offline
post #17 of 26 (permalink) Old 09-13-2019 Thread Starter
yamabond is high temp and will work with my stupid exhaust to manifold? i cant find any exhaust gasket that matches manifold
jdignan is offline
you can get gasket material at the auto parts store and cut one out yourself RTV orang is high temp silicone design for exhaust use you can also get that at the auto parts store but I don't recommend it because it tends to ooz and block some of the exhaust port but if your carfull you can just RTV it
We like to use yamabond or hondabond because it is resistant to two-stroke oil and fuel if you use RTV it will slowly erode away when used on a cylinder 2 crank case application
Think he is talking about compressing the rings on the piston to put the cyld on. If you have 2 wood ice cream sticks modified and someone hold the cyld you can press the rings in and slide the cyld over the piston.
Yamabond will not work on an exhaust manifold gasket neither will rubber fiber gasket material in the long run as the exhaust pipe will just cut right through it when the pipe bolts are tightened.....A real good exhaust gasket is layered with aluminum or made of thick layered graphite and beaded steel.....
https://www.ebay.com/itm/Exhaust-Gas....c100010.m2109
Do you have a lawnmower repair shop nearby? Tell them you want an exhaust gasket for an Echo backpack blower model PB503T...Just be prepared to pay 3x as much as the ebay link I provided.....
If you do and go there dont say pocketbike as most mowershops hate them and may refuse to sell parts to you.....
