need help identifying my pocket bike - Pocket Bike Forum - Mini Bikes
post #1 of 35 (permalink) Old 04-22-2010 Thread Starter
this is my new pocket bike but idk what make or model it is
locdog is offline
post #2 of 35 (permalink) Old 04-22-2010
Hooligan
SpyGuy's Avatar
Images: 23
Re: need help identifying my pocket bike
Only the first picture came out halfway decent ... the others are too dark to tell what it is. Put the bike in the driveway in full sunlight, and take a few more.
From what I can tell, that looks like it MAY be a Lucky 7, which is the best of the best of the Chinese-made air-cooled bikes. I can't be 100% certain on that, though, but the girder frame and removeable swingarm makes me think that's what it is.
SpyGuy is offline
post #3 of 35 (permalink) Old 04-23-2010 Thread Starter
aight ill put more up later
locdog is offline
post #4 of 35 (permalink) Old 04-24-2010 Thread Starter
here are tha pics of it
locdog is offline
post #5 of 35 (permalink) Old 04-25-2010 Thread Starter
tha new pics of it are up
locdog is offline
post #6 of 35 (permalink) Old 04-25-2010
Hooligan
SpyGuy's Avatar
Images: 23
Yah, that's a 7. Good bike.
SpyGuy is offline
post #7 of 35 (permalink) Old 04-26-2010 Thread Starter
do u know
why does it start bogging when i hit top speed?
locdog is offline
post #8 of 35 (permalink) Old 04-27-2010
Hooligan
SpyGuy's Avatar
Images: 23
One of two possible reasons:
-Not enough gas flowing into the carburetor.
-Top end reed flutter.
Gas flow: replace all lines with 1/4" fuel lines. Do the petcock mod, and install an inline fuel shutoff valve. Some people also bore out the barb on the bottom of the gas tank a little larger, too.
Top end reed flutter is when the reeds in the engine are flapping back and forth so fat that they can't make a good seal on the cylinder. Poor seal = loss of compression and power. Solution: change reeds out to better ones, such as carbon fiber or fiberglass. You can also change to a triple-stage reed set, such as the Black Widows, or do davation's cheap triple stage reed mod by cutting up the old tin reeds and layering them over a set of new reeds in your engine.
SpyGuy is offline
post #9 of 35 (permalink) Old 04-27-2010 Thread Starter
yeah ill probably bore the hole a lil bit and change the gas lines cuz idk how to do that petcock mod thingy.
ohh and what can i do to like make my pull starter last longer cuz ive already broke like 2 of them
locdog is offline
Hooligan
SpyGuy's Avatar
Images: 23
Petcock mod is easy - all you need is some J-B Weld. Take the petcock apart - the only piece of it you're going to use is the body. Lay the petcock body face-up (hole facing upwards) on the counter, and mix up some J-B Weld. Where the white knob was, you're going to fill in that hole. Once the J-B Weld has dried, stand the petcock up like you're installing it back on the carburetor. Now, get your drill, and very carefully go straight down through the barb on the top of the petcock, all the way down through the bottom hole. (Btw, don't forget to remove that O-ring on the bottom for this part, or else you'll tear it up and need to buy another.) Once you have it drilled out, re-install on the carb. Basically, what you're doing is making the petcock into a straight pipe, which is why you need the inline fuel shutoff.
As for the pullstart, sounds like you're pulling it too hard. When you pull, don't go all the way to the stop - do like a 3/4 pull.
SpyGuy is offline
post #11 of 35 (permalink) Old 04-27-2010 Thread Starter
aight ill do that later
also i have a problem with the back brakes when i push them to stop the lever doesent come back it stays there and the brakes dont engage at all
locdog is offline
post #12 of 35 (permalink) Old 05-03-2010 Thread Starter
[quote=SpyGuy;457463]Petcock mod is easy - all you need is some J-B Weld. Take the petcock apart - the only piece of it you're going to use is the body. Lay the petcock body face-up (hole facing upwards) on the counter, and mix up some J-B Weld. Where the white knob was, you're going to fill in that hole. Once the J-B Weld has dried, stand the petcock up like you're installing it back on the carburetor. Now, get your drill, and very carefully go straight down through the barb on the top of the petcock, all the way down through the bottom hole. (Btw, don't forget to remove that O-ring on the bottom for this part, or else you'll tear it up and need to buy another.) Once you have it drilled out, re-install on the carb. Basically, what you're doing is making the petcock into a straight pipe, which is why you need the inline fuel shutoff.
As for the pullstart, sounds like you're pulling it too hard. When you pull, don't go all the way to the stop - do like a 3/4 pull.[/quote
i need help today i was riding my pb and when i hit tha corner it turned off and it wont start back up i laready checked the carb and the jets
i took tha apark plug off and it was like grey color
do u think that i blew tha engine?
locdog is offline
Hooligan
SpyGuy's Avatar
Images: 23
Out of gas .............? Spark? Maybe the coil loosened up a little, and it's not gapped properly.
What's the bike doing, besides not working? Turning over okay, no grinding noises when you pull it? Let us know exactly what it's doing.
(Oh yeah, and you don't always need to hit the "Quote" button to post something here ... just go down to the bottom of the page, type your post in the box, and hit "Post Quick Reply", the button on the left.)
SpyGuy is offline
post #14 of 35 (permalink) Old 05-04-2010 Thread Starter
it doesnt make any wierd noises when i try to start it...i checked the spark plug and it wasnt grey it was goldish like carmel
should i maybe try starting fluid?
locdog is offline
I just bought a pocket bike from a friend and im not sure what brand model, 2 stroke or 4 stroke, etc. i know nothing about it besides it needs a new carb and exaust pipe. Also i know the serial number as well. Can anyone help me identify it please? Thank you
Bjr_22 is offline
How many inches are the rims, and what the numbers on the side of the tires??
EPR is online now
a serial number does very little...post up a picture...Use photobucket to post the pic to bypass the post count needed to post one in order to get identification sooner.....
It says my picture is too big to upload, but when i click yes for resize it doesnt do anything either so idk how to post a pick of it?
Bjr_22 is offline
Idk how to upload a picture?!
Bjr_22 is offline
Theres what my pocket bike looks like can someone tell me the engine size, model brand year etc anything you can figure out about it so i can order parts! Thank you
Bjr_22 is offline
