gearbox oil cateye fs-509 - Pocket Bike Forum - Mini Bikes
 3Likes
  • 1 Post By CAM2
  • 1 Post By MrKitty
  • 1 Post By CAM2
post #1 of 8 (permalink) Old 11-23-2019 Thread Starter
1badegg's Avatar
Question gearbox oil cateye fs-509
I recently purchased a cateye fs-509 49cc bike. How much gear oil (if any) is supposed to be in the gearbox in front of the clutch. It has a fill plug and drain plug, but when i took it apart to check the clutch it didn't have any in it. Just bearings and gears. thanks in advance.
1badegg is offline
post #2 of 8 (permalink) Old 11-23-2019
Re: gearbox oil cateye fs-509
It needs very little lube....Any more lube than just enough to touch the lowest gear and sling it around is too much and will seep into the clutchbell area.......
I like to run some Brasso and tranny fluid through it for a good 10-15 minutes to polish the gears then I clean out the gearbox and change the clutchbell bearing with a Higher quality which is a 6202-2RS size 35mm x 15mm x 11mm and remove the rubber seal from the side that sees the gear oil... ...
Most like SKF brand.I like SKF also Timken brand especially the deep groove radial ball bearing ABEC design bearings....
After you do the mod and refill with quality lube like Dexron Mercon Trans fluid or Lucas transmission treatment the trans will operate a lot smoother with lesser friction....
1badegg likes this.
post #3 of 8 (permalink) Old 11-23-2019 Thread Starter
1badegg's Avatar
Ok thanks. That is what I was thinking. I saw a youtube video and the guy was talking about filling it up. I sold Torrington/Fafnir bearings (which Timken bought them out) for 23 years so I'm a little familiar with brgs. I just wanted an expert opinion before I kept running it dry.I am new and definately a novice on pocket bikes. Thanks again!
1badegg is offline
post #4 of 8 (permalink) Old 11-23-2019
You definitely need to take it apart and clean out all the factory Grease...
Don't trust a lot of stuff you see on youtube a lot of people have just all of a sudden started thinking they're experts...
1badegg likes this.
post #5 of 8 (permalink) Old 11-23-2019 Thread Starter
1badegg's Avatar
ok thanks,Yes there is a lot of BS on you tube.
1badegg is offline
post #6 of 8 (permalink) Old 11-23-2019
Only put oil to near the bottom of the lower chain for lubing, anymore and it robs power. I just use 30w car oil about 100 ML.
post #7 of 8 (permalink) Old 11-23-2019
Hes got a FS509 Cateye with this type transmission..
This is the type of clutchbearing he needs....The china ones cant handle the load as well...
MiniPilot likes this.
post #8 of 8 (permalink) Old 11-24-2019
Yeah, I was thinking of the chain driven box. I have 2 of that type of trans on the twin Cag engines, will probably steal one when I put my new scooter engine in. I storage I have a set of Cateye front forks and rear arms section with the double barrel sprocket I picked up way back, from a member.
Tags
cateye gear oil
