pocket bike wiring diagrams for all - Page 3 - Pocket Bike Forum - Mini Bikes
 1Likes
Re: pocket bike wiring diagrams for all
Originally Posted by dmack View Post
It only took me 6 months to get around to this.
I am including 2 pics that should answer most of the wiring questions about an X1 or X2.
Would it be possible for you to post more pics such as the ignition coil, relay and starter motor, and kill switch, and where they connect?
Superdave1980 is offline
I believe this is a low numbered X bike wiring. You start by following the hot wire from the battery and from the generator housing. All the battery power goes thru the 10amp fuse, and there is a charging port wire hooked in to charge the battery. The starter/generator has 4 brushes, 2 for each purpose, starting and making power to charge your battery. It makes AC current so there is a voltage rectifier ( Diode ), that makes 13.7 volts DC, then you can charge your battery. The engine is like a chainsaw, it runs on its own.
i have a harley bike that i got sphegtti out of the wiring and need help to get it running
jaad1216 is offline
If you have a 2 stroke 49cc piston port engine, there is no wiring, you ground the coil thru a button to stop the engine. Most of the wiring you see with Cateye and X bikes with lights & blinkers and a battery to charge, and all the other junk they put on. I don't own a X1 or X2 bike.
49cc pocket bike x6 - i installed a push start button but wires get hot ( 1'POS-BATTERY 1'TO RELAY PIN 1'TO GROUND ) & also i have a starter switch 2 wire connector and another 2red wire 1coming from charger port other gussing ñegative cud i hook them up together..
Howlinwind is offline
Maybe the button wires are to small, or its not wired right, not sure what you did??
I have lost the key for my midi moto and I was wondering if there any way to start it without it it’s a 4 wire ignition wire colours are yellow orange red and white any suggestions much appreciated
Motorbikemad1970 is offline
Just pull the plug apart and pullstart it...To shut it off just replug it back together...
What do you mean
just unplug the key switch and then pull start the bike all the key dose is short the ignition to ground the key switch is more of a novelty and was never realley intended to prevent theft
What do you mean
You stated you wanted to know how to get the "bike started without the key"....?
I gave you the fastest and easiest answer by telling you to "unplug the keyswitch from the harness" and pullstart the bike which is a very viable answer to your question also to mention works on engines with pullstarters aswell as kickstarters......…
With Chinese wiring theres no definitive answer on "hotwiring" it seeings the Chinese use all sorts of different wire colors for the same termination on the same type harnesses due to the various different manufacturers plus you didn't give us the wire colors coming from the switch...…….Those colors are more pertinent..
For knowing that bit of info about which wires go where you need a multimeter to be absolutely sure which wires do what by doing a voltage check to find the power aswell as doing continuity tests to find the ground and killswitch wires or just buy a new keyswitch from ebay..
hey do you have anything with the name of the part for each number like your picture.
mtxaudio1435 is offline
What do you mean by unplug the key switch from the harness
Wow I know youre really not serious asking that...?...
I just screenshot the posts and sent it to my nephew....He sent me back an emoji banging its head against a brick wall ..
He said to ask google or find a youtube vid.........I agree....LOL
Take care..............
What brand is my pocket bike? eikcam Air Cooled Pocketbikes 14 02-05-2012 01:59 PM
Honolulu Meet? rossi808 Southwest 33 05-20-2009 07:25 AM
When you first get your Cag Pocket bike! insyder Air Cooled Pocketbikes 19 06-27-2007 09:18 PM
pocket bike question please help asnboi512 Chat 14 03-31-2006 12:23 AM
What is the 'super' in super pocket bike? nheaps Chat 12 06-05-2005 02:25 PM
