apc mini chopper scooter 43cc - Pocket Bike Forum - Mini Bikes
post #1 of 5 (permalink) Old 02-13-2018 Thread Starter
Seattlehawk56's Avatar
Question apc mini chopper scooter 43cc
hi everyone i was wondering do anyone have a diagram on a duel back wheel scooter i have 2 spacers not sure where they go
Seattlehawk56 is offline
post #2 of 5 (permalink) Old 02-14-2018
Re: apc mini chopper scooter 43cc
Here's a PDF for the electric version...the rearwheel assembly will be the same
https://www.google.com/url?sa=t&sour...qu8qRqEN63Qj4e
post #3 of 5 (permalink) Old 02-14-2018 Thread Starter
nothing on here about the rear tires
post #4 of 5 (permalink) Old 02-14-2018
There is you probably gleaned right over it,,,,The section simply states to take note as to how the rear is assembled before disassembly ....LOL
So its no help in that dept I guess....Without any visual help from you these help threads are useless....
Theres 6 spacers total in that rear assembly If I recall...two go between the wheel bearings in the rim hubs and the rest fit outside and inbetween
Going from brake side towards the sprocket side...[leftside to rightside]:
Nut,,axle adjuster,,frame,,small spacer,,band brake housing,,small spacer,,wheelbearing,,bearing spacer for wheel 1,,wheelbearing,,spacer between the wheels,,wheelbearing ,,bearing spacer for wheel 2,,wheelbearing,,medium spacer ,,frame,,axle adjuster,,nut
post #5 of 5 (permalink) Old 02-15-2018 Thread Starter
wow i took it apart and only 2 spacers plus 2 interlocking spacers blocks in the middle
