Petcock Mod - Pocket Bike Forum - Mini Bikes
post #1 of 90 (permalink) Old 04-05-2008 Thread Starter
Talking Petcock Mod
Here is how to do the petcock mod for the stock 49/47cc cags....
1: remove petcock from carb..
2: remove the small o ring from the bottom of the petcock
3: disasemble petcock
4: J-B weld the area where the white knob was
5: drill through the petcock where the fuel line is conected all the way to the bottom of the petcock where the little o ring was.(make shure you drill big enough so that you get good gas flow
6: put the little o ring back on the petcock
7: Put the petcock back onto the carb
8: install an inline fuel shut off valve
here are a few pics
cpparent is offline
post #2 of 90 (permalink) Old 04-06-2008
Slayer0420's Avatar
Re: Petcock Mod
Sikk! I was going to do a thread about this. Saved me some time! Thanks CPP!
I WANNA GO FAST! Always Wrap You're Piston!
Slayer0420 is offline
post #3 of 90 (permalink) Old 04-06-2008
Re: Petcock Mod
Now I may be the only one out of the loop but what will this accomplish? Is it letting better fuel flow through the carb? If so, how?
Lmidgitd is offline
post #4 of 90 (permalink) Old 04-06-2008
Slayer0420's Avatar
Re: Petcock Mod
No the petcock jams all the time so using jb weld and a drill you make it stay open and install an inline cut off valve to turn it on, and off. Instead of turning the white knob you turn a cut off valve its much easier!
post #5 of 90 (permalink) Old 04-06-2008
matty boi's Avatar
Images: 16
Re: Petcock Mod
it also helps fuel flow. if your engine is highly modified and requires more fuel the petcock will be restricting too much fuel, so by completely drilling through it you get better flow.
RIDE or DIE!
Banshee SHO, heavily modified cag, stock cag, 120cc cateye, x18, modified gx140 HPE/Muskin 400 EL... all sold the end..
matty boi is offline
post #6 of 90 (permalink) Old 04-06-2008
Re: Petcock Mod
Thanks for the answer fellas. Luckily this thread wasn't on the other day otherwise I would have done it instead of purchasing a two dollar fuel filter that fixed my problem, haha.
Lmidgitd is offline
post #7 of 90 (permalink) Old 04-06-2008
Slayer0420's Avatar
Re: Petcock Mod
I would still do this mod or at least just leave the white knob on and use an inline shut off valve !
post #8 of 90 (permalink) Old 04-07-2008
Re: Petcock Mod
just a thought, who thinks that incresing the diameter of the fuel line its self would have an effect?
kgogarty is offline
post #9 of 90 (permalink) Old 04-07-2008 Thread Starter
Re: Petcock Mod
no i do not think that will change much since the petcock itself is smaller thus restricting the line
cpparent is offline
Slayer0420's Avatar
Re: Petcock Mod
I'm going to do the petcock on my spare carb today!
sizematters?'s Avatar
Images: 12
Re: Petcock Mod
i fab'd a plate to cover the area where the knob goes, using the existing plate as a template and left the little holes inside. i used silicone gasket maker to seal it. bike runs good.
Adventure is often discomfort remembered.
sizematters? is offline
post #12 of 90 (permalink) Old 04-08-2008 Thread Starter
Re: Petcock Mod
yup and if you want more gas flow you can drill through bigger...
cpparent is offline
Pocketbike Champ
Bighomedog11's Avatar
Images: 8
Send a message via AIM to Bighomedog11 Send a message via MSN to Bighomedog11 Send a message via Yahoo to Bighomedog11
Re: Petcock Mod
I did that samething. I made a metal plate for mine and bolted it back into the petcock were the knob was but i have the JB under my plate.
Bighomedog11 is offline
Slayer0420's Avatar
Re: Petcock Mod
Good idea guys! would look much better!
post #15 of 90 (permalink) Old 04-08-2008 Thread Starter
Re: Petcock Mod
I have to agree that some good thinking there fellas keep up the good work
cpparent is offline
Images: 1
Re: Petcock Mod
Do you have pics of the plate mod you did to the petcock? Thanks.
PaulEvan is offline
Images: 1
Re: Petcock Mod
And, CPParent, if I've got this right, after the JB Weld has cured then drill through the tube openings on the petcock valve so there is continuous flow through? Does anyone have photos of the drilling process? I just don't want to screw this up or my sons will kill me.
PaulEvan is offline
capt highsider's Avatar
Re: Petcock Mod
yup after the JB weld has cured 24hrs. then get a dril bit thats the same size as the hole at the top then just drill it straight through on a drill press if you have one available. You really cant screw this one up
capt highsider is offline
post #19 of 90 (permalink) Old 04-15-2008 Thread Starter
Re: Petcock Mod
yup thats right I use a 5/32 drill dont forget to take out the small seal at the bottom before you drill because it will rip if you dont take it off..
cpparent is offline
Images: 1
Re: Petcock Mod
What does the small seal look like or are you referring to the small O-ring?
PaulEvan is offline
