APC Mini Chopper Replace Chain? - Pocket Bike Forum - Mini Bikes
post #1 of 4 (permalink) Old 05-13-2019 Thread Starter
themuppetman's Avatar
Hi There! I have a Pep Boys APC Mini Chopper and need to replace the chain.
Any recommendations on how to do this?
1. I have the chain loose-- but notice it needs to be taken apart since it goes around part of the frame.
2. I also need to know what size to purchase?
THANK YOU SO MUCH
themuppetman is offline
post #2 of 4 (permalink) Old 05-13-2019
Re: APC Mini Chopper Replace Chain?
THANK YOU SO MUCH
Welcome to the forum
You can buy some replacement chain for a garage door opener for cheap and use a chain breaker/mender tool to make appropriate sized chain and splice it back together for the same price as one from ebay in which youll still need a chainbreaker/mender tool.
https://www.ebay.com/itm/CHAMBERLAIN...ox!11757!US!-1
https://www.ebay.com/itm/Chain-Cutte...MAAOSws6ha16B9
post #3 of 4 (permalink) Old 06-01-2019 Thread Starter
Just a quick update.. the chain that CAM2 recommended fit perfectly..
And.. there's enough for an extra chain...
Thank you CAM2
post #4 of 4 (permalink) Old 06-01-2019
Thank you CAM2
You're welcome muppetman..
I like to improvise ways to maximize the need with better quality items that give way more than needed for the same $$ as the cheaper stuff for less or the same price.
For me owning as many pb's that utilize the same chain buying it in large quantity is more cost effective for me..
One thing I shouldve mentioned is the first time chain useage initial chain treatment that uses light duty oil,,1/2 of a parafin wax cube,a coffee can and some heat...
The treament infuses all the nooks and crannies in the rollers to be filled with lube that lasts quite awhile and helps break-in the chain flawlessly to reduce as much friction as possible..
Take care....
Tags
apc , chain , mini chopper , pepboys
apc mini chopper -pepboys-A&A m1 raceing Mini Choppers 312 3 Weeks Ago 08:25 PM
APC Mini Chopper Questions Tazz'APC Mini Choppers 48 07-07-2019 11:56 AM
VIDEO: How to remove and replace chain and adjust chain tension on a mini pocket rock guitarplayer Air Cooled Pocketbikes 0 09-15-2011 06:39 PM
APC mini chopper question gmaguitar01 Mini Choppers 2 06-18-2008 12:24 AM
