Double rear wheel assembly - Pocket Bike Forum - Mini Bikes
post #1 of 6 (permalink) Old 3 Weeks Ago Thread Starter
themuppetman's Avatar
I screwed up... I removed the back double tires on my apc pep boys mini Harley chopper and now I can't figure out where the different size spacers go.. anyone have a diagram of the order? Any help is much much appreciated!
File Type: png Screenshot_20190527-181711_1558995608369.png (85.4 KB, 3 views)
themuppetman is offline
post #2 of 6 (permalink) Old 3 Weeks Ago
Re: Double rear wheel assembly
Put your chain on and line it up with the front sprocket, that should show you how much spacing you need. You can add SS .060" thick washers 9/16 and 5/8 for smaller adjustments.
post #3 of 6 (permalink) Old 3 Weeks Ago Thread Starter
Sorry -- to clarify -- I have a pile of Wheels, Tubes (different sizes) and bearings.
Not sure which order they all go in!
Thank you in advance
post #4 of 6 (permalink) Old 3 Weeks Ago
If you post photos of the parts you have CAM2 will be able to help you. It helps to take photos as you take stuff apart, helps a lot when you put it back together,
post #5 of 6 (permalink) Old 3 Weeks Ago
ok so the two spacers that are the same size go inside the wheels the medium spacer goes between the two wheels the small one goes between the frame and drum the next smallest one goes between the drum and wheel the last one goes on the sprocket side spin the wheels well you tighten it up if it starts binding stop and rethink if you crack a wheel its finished you cant get them anymore...
i think thats correct i haven't seen one in a very long time
post #6 of 6 (permalink) Old 3 Weeks Ago
Putting the rimhalves back together should be a no-brainer as the rimhalves kinda marry themselves..
Heres some pics that may help you so you can see what Im saying.........
