help on mini chopper wiring - Pocket Bike Forum - Mini Bikes
post #1 of 9 (permalink) Old 06-11-2006 Thread Starter
i have a 49cc mini chopper, it has no namebrand so i think its chinese.
one day for some unknown reason, i decided since the battery was dead and it would be too much of a hastle to charge it, i would take out all the lights and wires and anything at all thats electronic.
after i took all the lights and the dials off, i noticed a few wires coming out of the motor, i dont know anything about what they do or why they are there so i left them, now my bike wont start. the wires coming out of the motor are still there and they have they are connected to some cylindre type thing which is about an inch long, and thats connected to a a siver rectangle box thing thats about 3 inches by two inches, and theats connected to a black box thing with holes in it that looks like this/ <o>
i still have all the wires, i just want the thing to run. what do i do?
i just wanna ride my bike
Elisaac is offline
post #2 of 9 (permalink) Old 06-12-2006
Images: 2
Re: help on mini chopper wiring
Well,i dont know why u wanted to do that but if u unhooked the keyswitch wires that are from the ignition coil then it aint gonna start.u should just charge the battery and leave every thing on.
ScooterJunkie is offline
post #3 of 9 (permalink) Old 06-12-2006
well u should put every thing back together and post it on here after you are done and tell us what happened
chopper dude is offline
post #4 of 9 (permalink) Old 06-12-2006
Images: 2
If u need to finding a battery then try Radio Shack they have one for 15 bucks.12v.work way better that the china ones.
post #5 of 9 (permalink) Old 06-15-2006
Images: 2
Well dude r u gonna try gettin a new battery?
post #6 of 9 (permalink) Old 07-26-2006
I HAVE THE SAME PROBLEM! how do u charge the battery
boyz toyz is offline
post #7 of 9 (permalink) Old 07-28-2006
Images: 2
dude you get the charger and you plug it in to the wall and the bike.
post #8 of 9 (permalink) Old 05-12-2019
I am rebuilding a chopper with a 49cc, lights, starter, stator and headlight.
All the wiring shorted at some point and I am replacing the wiring. The plastic plugs are still in good shape so I am gonna splice new wiring at the plugs. Can I find a wiring diagram? No success so far.
I ordered a new box (3 wire under the tank). awaiting it's arrival.
The starter works when hot wired and the bike runs pretty good.
The solenoid works as well.
I have a 3 wire plug labeled 'Switch' but I don't have a switch. Is this needed and where can I get it?
I would rather purchase a new harness but can't find one.
mimsand is offline
post #9 of 9 (permalink) Old 05-12-2019
Welcome to the forum............
If replacing all the wiring you should make due with a simplified wiring system...…
You can get a 4 wire keyswitch from ebay….
Youll notice on the schematic theres only 2 wires....The other two are for the killswitch for the ignition coil which isn't pictured as it is its own separate system...
File Type: jpg Typical2strokestartandchargersystem_zps61f404f0.jpg (53.8 KB, 4 views)
mini quad vs mini dirt bike JRZRacing Minimotards, Mini Dirt bikes & Mini Quads 7 08-06-2016 06:34 AM
Pocket bikes and mini chopper from china factory needs a tehnical shop ez-agents Air Cooled Pocketbikes 6 10-16-2004 11:17 AM
Pocket bikes and mini chopper from china factory needs a tehnical shop ez-agents Chat 2 10-15-2004 09:58 PM
