apc mini chopper -pepboys-A&A - Page 16 - Pocket Bike Forum - Mini Bikes
 6Likes
Re: apc mini chopper -pepboys-A&A
Originally Posted by chevale View Post
Very cool, CAM2!
My project is moving slowly. Have to source rubber primer for carb (the original one is cracked) or better to buy a new carb? In the end it's only $15. Also looking what material to use for exhaust gasket.
Thanks a lot...Almost everything was gleaned from junk bikes.....The chain was literally the only thing I bought.....
Alot of the extra left over parts went into building this....
And this....I put the other half of the band brake rim on the sprocket side and added a spin-on 17tth freewheel sprocket to the bandbrake hub and melded the 17tth freewheel with a 38tth rear sprocket
A new primer bulb you can get from Home Depot...........
Or you can get both from ebay or the local mowershop.........
https://www.ebay.com/itm/10pcs-Prime...4AAOSwsXpdCJi~
https://www.ebay.com/itm/Muffler-Exh...MAAOSwZNtcDzGm
Keep up the good work and Good luck......
Oh BTW.....Are you still looking for that front rim....?
Very cool, CAM2!
can I see a few photos of ur wireing please?
Austin Duffy is offline
Johnnymerk808's Avatar
Do you guys think this would work for a back tire and rim to replace the dually on the apc mini chopper?
File Type: jpg Screenshot_20190713-145311_Chrome_1563051317132.jpg (427.7 KB, 4 views)
Johnnymerk808 is offline
No....you would be better off buying a set of 6.5" cag wheels or atleast the rear.......
The rim you have pictured is the same exact width as a single rear wheel from your current setup.The rear would look like you just removed the rear tire on the left and will need to put like a 5" spacer on the left side so you can hook the chain up properly . ...
The rear rim needs to be something like 8 - 9" from sprocket to brake hub.....
I would gladly do that except that my twin engine dragbike has only has a double killswitch setup
I have a easy to follow quick n easy schematic to thinning down the troublesome wiring then piggybacking on the lighting afterwards...
That's why I said to get a multimeter.....pictures will mean virtually nothing....
EPR posted a schematic. ..if you can't follow that I suggest the easy to do schematic that's so easy a 12 year old can do....
Thanks, kids fixed the broken one. Will see how this will hold, there is not much stress so I assume it should be OK
chevale is offline
Will do a bit later as now it's all in pieces.
A few photos I have before disassembly attached.
Hope this helps.
chevale is offline
Hope this helps.
thankyou so much finaly some photos!!!
Cam 2, Thanks again for your help and advise on the rim. I would really like to get that rim and tire that you have if your still interested in getting rid of it. Please let me know.
The front wheel assembly I posted for chevale?
I dont have any spare cag rear wheels ATM .......
Hey I need a throttle arm or linkage for my gx200 does anyone have one they could give me or sell to me?
Have you called Honda.
affordablekarting.com
