Fuel Flow Problem -- APC Mini Chopper - Page 3 - Pocket Bike Forum - Mini Bikes
 1Likes
Re: Fuel Flow Problem -- APC Mini Chopper
Originally Posted by scotty1031 View Post
Something with bigger tires and a lil more ***. Would be Great. I'll find one and ya'all will know
Sometimes its alot easier to customize what you have..You can get those things up to 60-65mph with a 7hp predator engine from Harbor Freight with governor removal mod and mods to allow for the higher revs without exploding the engine .. Youll also need a $50 T-A-V from ebay..
I stuck a second engine on my mini harley...I also stretched the frame a lil longer too..
Any clue the year or the maker?
scotty1031 is offline
Cool, Twin engines. I'm guessing a 7hp is bigger than a 49cc and prolly haul my butt. Yeah. Mounting and functionally? idk
What is a T-A-V ?
I'm liking the bigger tires in pics. Maybe I need to try riding mine on a blacktop road, gravel road is not to friendly. lol
Cam2
I'm back. lol
DO you have any idea where I can find a quality rope starter?
I replaced my starter twice and again it's skipping on the cogs and now the rope pulls fine but wont engage.
Looking, I found some with a metal cog thing and don't know what that's for or how to install it, if mine has one of those?
But they're plastic pull engage gear worries me
I have another replacement but the 1st two broke, so why try to use it.
Again I need a lead
Frustrated
Thanks
Scott
What is a T-A-V ?
Torque-a-verter
Cam2
I'm back. lol
Again I need a lead
Frustrated
Thanks
Scott
If you dont have the GSMoon style pullstarter and pawl I suggest one and if its the type youre talking about there are two stainless steel wires that make contact with the pawl...
Its the most toughest pullstarter out of the other 2 thats out there now..I pullstart engines that are 200-220psi and only issue was breaking the cord...LOL
If you don't install the thin aluminum shim between the e-starter and the pullstarter it will cause skipping problems in the pullstarter
I use #5 or #6 chainsaw starter rope and rewind the pulley, at least on a reed port engine. On my piston ports I just buy a new starter housing.
Thanks For help, I'll find one.
Um, would it hurt to replace the pawl assm. on mine. along with the starter?
The rope starter part has two plastic cogs in the housing attached to the rope recoil wheel. It has to turn the crank, pawls are the only thing between?
How to change pawl assm. if it's needed?
Thanks for reply
Scott
dont waste your time buy a few new ones and keep them on hand
dont yank on the rope what you do is pull the starter gently untill it engages then pull if you have to yank over and over your engine is not tuned properly
Sounds like you have the alum rectangle starter pawl with plastic cam on the pulley. They sell sets for both types. You remove that big nut on the crankshaft end and remove it, think its threaded on. On eBay search 43cc - 49cc X1, X7 pocket bike engine parts, should be able to find something there. Do you have the flat alum shim that goes between the starter housing and engine case??
Thanks for reply
Scott
If you have the rectangle with plastic catch you do realize even when the pullstarter isnt being pulled the spring loaded plastic catch always makes contact with the pullstarter..
With the gsmoon setup the pullstarter only makes contact with the pawl when the rope is being yanked..
Your choice but I will say that swapping to a GSmoon setup is as easy as swapping out the bad pawl for a good one and you wont need extras...
The gsmoon pull and pawl are on ebay for like 12 bux free shipping...
post #54 of 55 (permalink) Old 4 Weeks Ago
Cam2
I finally got a double pawl assm. and a four cog rope starter. After figuring out how to unscrew the pawl assm. from the crank, I reinstalled it and holy cr*p it works so good. No hiccups. Dependable. Happy Camper.
Thank You
Scott
post #55 of 55 (permalink) Old 4 Weeks Ago
Cam2
Thank You
Scott
You're Welcome Scott and Good to hear your problem is fixed..Thanks for the update..
