Ktm50 swap into cag - Pocket Bike Forum - Mini Bikes
post #1 of 5 (permalink) Old 05-26-2019 Thread Starter
Ktm50 swap into cag
Good Evening
Would like to swap a ktm50 lc motor
Into my cag.
Is this feasible?
Thanks for any and all input
Superman12# is offline
post #2 of 5 (permalink) Old 05-27-2019
i dont see why not keep in mind those ktm engines start falling off around 12000rpm stock they are a bit spendy as well you will get way more bang for your buck reworking a stock cag engine with a dremel
post #3 of 5 (permalink) Old 05-27-2019
Re: Ktm50 swap into cag
[quote=MrKitty;901291]i dont see why not ke
ep in mind those ktm engines start falling off around 12000rpm stock they are a bit spendy as well you will get way more bang for your buck reworking a stock cag engine with a dremel[/quote)
Umm those KTM50 engines are about 9hp with an optional 5.5hp detuning kit that's available to detune it for the younger riders.
Even the clone version has over 7hp....
It takes a real lot of trick porting and tuning on methanol to even come close with a cag engine..The pic below is what you have to do to get 10hp with a cag engine....It's 100% race only and costs more yo build than buying the KTM engine..
In any event if he does decide to go through the headache he will be building a suicide machine........
It would be better off building a pocket dirtbike or pocketquad instead....LOL
post #4 of 5 (permalink) Old 05-27-2019
LOL the crazy frog
where the bike shoots out from under you and your ridding nothing but air for a split second
Or like what happened to Nipples when his frame basically cracked in half while he was riding...
From what I've learned on this form just about anything is possible...
https://youtu.be/k85mRPqvMbE
File Type: jpg 7e0b9f8e48ed84741f1c71650ca845bc_1559000318962.jpg (169.4 KB, 13 views)
post #5 of 5 (permalink) Old 06-19-2019
Rcfish90's Avatar
Originally Posted by Superman12# View Post
Good Evening
Into my cag.
Is this feasible?
Or you could also buy a 70cc vmc/avotechnica engine, its basicly a reinforced cag engine with a bigger stroke crank and a bigger and better cylinder base, and you have unlimited posibileties in aftermarket cylinder choice
Aswell in air cooled or liquid cooled cylinders.
you can mount any cylinder that is made for a minareli horizontal and their are allot performance cylinders fabricated by the brands,
(athena/stage6, malossi, polini, hebo, metrakit and allot more brands.)
Personally i am still running the 70cc ac cylinder that came with the engine as it is allready very powerfull, but if it ever breaks down on me then i will look to buy a 70cc lc cylinder kit and add a waterpump and a radiator on the engine
Verstuurd vanaf mijn SM-G960F met Tapatalk
Rcfish90 is offline
Starting on the 212 swap into a Cateye wetzeb General Pocketbike Discussion 1 05-23-2017 10:34 PM
139QMB swap into X7 markkusss Midbikes / Superbikes 35 04-28-2017 06:48 AM
ktm50 in cag? SCRracing Air Cooled Pocketbikes 11 10-24-2011 11:11 PM
gx200 clone swap into xp-490 cateye help. 196ccCatEye Midbikes / Superbikes 8 04-15-2008 08:23 AM
