Condition of clutch - Pocket Bike Forum - Mini Bikes
post #1 of 28 (permalink) Old 01-03-2019 Thread Starter
Maird79's Avatar
Hello everyone
I'm going to make a start on the engine on my Blata B1
In a effort to try and keep costs down for the project
What do you think of the condition of the clutch
It looks like it has lots of pad still
When it's been cleaned up im thinking it should be ok to stick it back in
Any thoughts. Cheers
Maird79 is offline
post #2 of 28 (permalink) Old 01-03-2019
if there is pad it's still good in my opinion
MrKitty is online now
post #3 of 28 (permalink) Old 01-03-2019
Re: Condition of clutch
Originally Posted by Maird79 View Post
Hello everyone
It looks like it has lots of tread still on the shoes. When it's been cleaned up a bit I'm thinking it should be ok to stick it back in
Springs look cooked to hell..Pads are ok but are misadjusted aswell…One arm is a lot more closer to the bell then the other 2 but all 3 aren't set the same.
Looks like a novice rider was riding it.Theres a reason theyre called racing bikes...LOL
You want to stab the throttle and just hold on and maneuver...Blipping the throttle sounds cool but really isnt.
You see the toll it takes on clutch springs....Over time the metal and clutch abrasive is gonna start to wear away at the crank seal.its best to remove the debris like you mentioned with brake parts cleaner then spot lube the seal with an oiler pen
Id still buy a new clutch and keep the old one for a spare..
post #4 of 28 (permalink) Old 01-03-2019 Thread Starter
Maird79's Avatar
Thanks for the advise👨‍🔧👍
Maird79 is offline
post #5 of 28 (permalink) Old 01-04-2019
Chrisi's Avatar
Just take a look to the end of the arms of the clutch there is a small nose, so there is only 1- 1,5mm material is left.
The clutchbell should be only 1-2mm bigger than the clutcharms.
The springs 😅😅 a little rusty.
Chrisi is offline
post #6 of 28 (permalink) Old 01-04-2019 Thread Starter
Maird79's Avatar
I'm thinking follow cam2 advise and get new clutch and use the old one for spares . Didn't want to buy a new one if it could be helped. Because the parts list was getting lengthy. Just 1 clutch puller is like £25
Maird79 is offline
post #7 of 28 (permalink) Old 01-04-2019
Chrisi's Avatar
When you buy a new clutch, you can mad the clutchpuller from the old groundplate of the old clutch.
In the pics i made it for cage clutch but same way works with blata rep clutches.
In the middle i weldet an M 8 nut.
In the blataclutcheplate are already three holes you must only threading a M 5 or a M 6
File Type: jpg 15466138621481125375264_1546613884896.jpg (330.4 KB, 6 views)
File Type: jpg 1546613904136953132436_1546613922131.jpg (354.4 KB, 5 views)
File Type: jpg 1546614150111615802709_1546614220997.jpg (421.6 KB, 5 views)
Chrisi is offline
post #8 of 28 (permalink) Old 01-04-2019 Thread Starter
Maird79's Avatar
Wow🤔 so I can make a clutch puller from the old clutch? Good idea👍
But I would still need to buy a clutch remover first wouldn't I ?
Maird79 is offline
post #9 of 28 (permalink) Old 01-04-2019 Thread Starter
Maird79's Avatar
Which type of lubricant do you use in the oiler pen to lube crank seals. Thanks
Maird79 is offline
Chrisi's Avatar
Cut 3-threads, turn screws's into like on the pic, when screw's hit the crankcase the turne them only a step, then the next and so on. So can get it off for the first time
For the first run give the oilseals some 2 strokeoil and thats it.
File Type: jpg 1546615631639568020707_1546615648411.jpg (389.0 KB, 5 views)
Chrisi is offline
I use Cerflon.Its a wet Teflon with ceramic that dries and stays where its put and doesnt collect clutch dust like 2 stroke oil does and its twice as slick too...........
Cerflon ? Cerflon ? Ceramic Reinforced Fluoropolymer
Another thing I use is Next Dimension white graphite.Its a chain lube sold by most Honda dealerships..It works excellent on chains too..Way better than chain wax.
The B1 / C1 clutch is on a straight shaft with key, it should be pretty easy to get it to slide off. I use 3 in 1 oil in a little squeeze can, on everything, cylinder, piston, bearings and seals when I am rebuilding. I over heated my C1 clutch and a pad came off and wedged its self between the other pad and bell, I though I blew it up at first.
post #13 of 28 (permalink) Old 01-06-2019 Thread Starter
Maird79's Avatar
Hi
Thanks for the diy clutch guide. Hope I got it right. What length in mm do the 3 bolts need to be
Maird79 is offline
post #14 of 28 (permalink) Old 01-06-2019 Thread Starter
Maird79's Avatar
Hopefully once I blowtorch and liquify the loctite it should come off🙏
Maird79 is offline
Hi
Long enough to make contact with the crankcase but theres a huge risk to doing it wrong which is a cracked case..
Heres what Id do if i had to go that route.,,,
Put descent even pressure on all 3 screws then hit the crank snout end til it gets to around 150-160 degrees or you hear the clutch mount pop from the crank.
If no pop give the center screw some more pressure and that should get it to release while being held securely..
Those engines run up to 230 degrees aircooled and 200 watercooled to give you an idea on the kinda indirect heat the seal can take....
you can also do it with shorter screws just enough to hold the plate but then you need something to stop the crank from spinning...
post #16 of 28 (permalink) Old 01-06-2019 Thread Starter
Maird79's Avatar
Thanks 👍
Maird79 is offline
Thanks 👍
Oh and you dont have to weld the nut...just hold the nut with a box wrench and turn the bolt.
post #18 of 28 (permalink) Old 01-06-2019 Thread Starter
Maird79's Avatar
What's the length in mm
Of the middle hexagon screw
Maird79 is offline
You need lock nuts on the adjustment screws to keep it from turning. I would get new springs there under $20, and I would grind half the alum lips down to give you more pad thickness so it down hit the bell. Take the clutch & arms off to modify and clean everything, any decent hardware has metri nuts & bolts. You can buy just the clutch arms w/ pad in a set. BZM has clutches for it too. On my GRC GP avatar photo I found a new $175 BZM racing clutch for $68, I snapped it up so fast, lol. This is a real B1 Blata right??
Chrisi's Avatar
50-60mm is long enough
Chrisi is offline
