Clutch engagament - Pocket Bike Forum - Mini Bikes
post #1 of 10 (permalink) Old 06-20-2019 Thread Starter
MGC
Clutch engagament
Hello
Not sure if this is normal or not.
When I give my bike the throttle,the clutch does not engage until the the throttle is about 3/4 full.
Does anyone know if this is correct or when the clutch should engage?
Thank you
MGC is offline
post #2 of 10 (permalink) Old 06-20-2019
Re: Clutch engagament
Originally Posted by MGC View Post
Hello
Thank you
Its a racebike and the clutch should engage around 8k rpm's.....
If you dont have an RPM gauge its gonna be hard to figure out....I use a TrailTech TTO..........
Chances are youre gonna need a new clutch...remove the clutchbell housing and take a peek......
post #3 of 10 (permalink) Old 06-21-2019 Thread Starter
MGC
Thanks for the info
I have never never taken the clutch apart.
What would I be looking for?
MGC is offline
post #4 of 10 (permalink) Old 06-21-2019
Thanks for the info
Youre only removing the clutchbell housing to do the inspection.Its easy..
You'd be looking for clutchpads that are burnt or too thin past its effectivity,rusted and highly oxidzed looking parts,glazed clutchdrum,,also check that the clutchbell drum bearing rolls smoothly......
If all looks well try roughening up the clutchpads plus deglazing the clutchdrum with 100 grit sandpaper then try backing off on the 3 adjustment nuts a half a turn each or whats also referred to as "3 flats of the nut" then retry.
post #5 of 10 (permalink) Old 06-22-2019 Thread Starter
MGC
Thanks I will take apart and have a look.
MGC is offline
post #6 of 10 (permalink) Old 06-23-2019 Thread Starter
MGC
Hello
Thanks again for your help.
I have taken the clutch out, springs are rusted so I have ordered a new one.
In looking at the bell housing it does not turn freely. I am looking to replace but this one is held on by 3 screws and everything online I see to purchase is 4 screws only, any ideas?
Thanks
MGC is offline
post #7 of 10 (permalink) Old 06-23-2019
Hello
Thanks
Heres a link to what youre looking for............
https://www.ebay.com/itm/Gear-box-6T...pe!11767!US!-1
Just so you know your bike is known as a MT-A4 39cc watercooled C1/B1 Blata replica....
It helps a lot in finding parts when you know the technical name........
It maybe a lot cheaper to buy a new bearing and replace it depending on whether or not you own an 18v impact gun and a gator grip socket to remove the pinion without damaging it...
post #8 of 10 (permalink) Old 06-23-2019
I have seen them for $20, I have three, 6, 7 and 8 tooth. I would get a 7 tooth pinion one, search eBay, 39cc 2 stroke C1 water cooled pocket bike parts. You can change the rear sprocket teeth 55 to 78 teeth also.
post #9 of 10 (permalink) Old 08-12-2019
johnni's Avatar
I think I will need to buy a new clutch soon as well as a spare for my blata b1 rep w/c bike. Does anyone have a link in which clutch I should buy ?
Thanks
johnni is offline
Chrisi's Avatar
Can over you 3 different clutches
Zocchi Carbon 2 shoe 65€
Zocchi Carbon 3 shoe 75€
Blata original 3 shoe 65€
All + shipping
File Type: jpg 15655977712564060658146913697550_1565597781186.jpg (464.0 KB, 5 views)
Chrisi is offline
