Motor identification help please - Page 3 - Pocket Bike Forum - Mini Bikes
 1Likes
Chrisi's Avatar
One question, can you open your clutch case when the engine is mounted?
Chrisi is online now
post #42 of 125 (permalink) Old 08-12-2019 Thread Starter
Kimjon's Avatar
Yes, easy. Plenty of access to it<img src="https://www.pocketbikeplanet.com/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />20190811_170835_1565588688913.jpg
Kimjon is offline
post #43 of 125 (permalink) Old 08-14-2019 Thread Starter
Kimjon's Avatar
How much water (using g 50:50 coolant mix) does the system hold?
I put some in...but it hardly took much to fill it? Perhaps its air locked...or maybe it doesn't need that much to begin with?
I guess I'll start it up and see if it draws more in?
Any hints?
Kimjon is offline
Chrisi's Avatar
Should be about 750-1000ml,depending on the radiator and the hous diameter, fill in about 500ml,then start the engine and pull the bike in the front up, like a wheely, so the should be the most air out of the system and you can fill up the rest.
post #45 of 125 (permalink) Old 08-14-2019 Thread Starter
Kimjon's Avatar
Thanks. Okay...I have a long way to go, as I think I've only put about 100ml in there right now. I'll leave it overnight and perhaps turn the water pump over with a drill or something similar to work the water through. I'll also try the lifting front up like you've suggested. Thanks.
Kimjon is offline
Re: Motor identification help please
Mine only holds about 8 to 12oz.
post #47 of 125 (permalink) Old 08-15-2019 Thread Starter
Kimjon's Avatar
Thanks for feedback. Yeah only holds a few hundred millilitres. About a cup at the most???
https://youtu.be/X2zwPhxAQ4I
First start up!!! Needs a different carburetor to make it run better, but I'll sort that out.
Kimjon is offline
post #48 of 125 (permalink) Old 08-15-2019 Thread Starter
Kimjon's Avatar
Got it sorted!!! So loud, seriously think I've damaged my hearing. Ear plugs a must!
https://youtu.be/iW9KgtDn1E8
Kimjon is offline
post #49 of 125 (permalink) Old 08-15-2019 Thread Starter
Kimjon's Avatar
You can see in the second YouTube clip theres a slight coolant leak coming from the bottom of the pull start area. I'm hoping the seals hydrate and seal, otherwise I'll take it apart.
I assume it's from the shaft seal on the drive pulley? Although I took the pull start cover off and it looks dry? So a bit of a mystery. I'll probably just run it and top up if it's not glaringly obvious where its coming from.
Kimjon is offline
Chrisi's Avatar
That's the problem with the Blata rep engine, there is a shaftseal ring and you could only change this sealing when you demount the crankhous&#x1f622;&#x1f622;.
File Type: jpg 15658590314043749004904162849569_1565859053190.jpg (392.7 KB, 4 views)
File Type: jpg Screenshot_20190815_105838_com_1565859544946.android.chrome.jpg (103.4 KB, 4 views)
post #51 of 125 (permalink) Old 08-15-2019 Thread Starter
Kimjon's Avatar
Oh...hmmmm, not great. I really don't want to do this right now, as we're all racing next week (12 school friends each with a drift trike, which happens once a year).
If I leave it, is it likely to damage the motor?
Kimjon is offline
Chrisi's Avatar
The water destroys the bearing and the water pump won't turn any more, you get an overheating engine maybe an damaged cylinder and so on.
post #53 of 125 (permalink) Old 08-15-2019 Thread Starter
Kimjon's Avatar
Okay, thanks. I'll repair it then.
Kimjon is offline
post #54 of 125 (permalink) Old 08-16-2019 Thread Starter
Kimjon's Avatar
Found the leak, it was the overflow bottle cap. It wasn't 100% sealing and the drip followed down a hose, onto another hose...then dripped to ground near motor. So mystery solved.
In other news:
Well, it goes. But it sucks down low! To be honest its possibly a little less power than I was expecting???
Theres not enough room on my drive to get into power band, and that's when it should liven up a lot. But it has zero low down torque. I'll change the rear sprocket for a 78 tooth, from the 68 tooth that's on it now. That will help.
But I think it's just going to need more room to show its potential, which will be the case on race day. The yard we use is about 100m long so it will be awesome on the straights, just not so great on the corners.
Still...I've enjoyed making it and learnt heaps. Thanks for all the help everyone on here provided.
https://youtu.be/zFSAzUNUc-g
Kimjon is offline
Chrisi's Avatar
At what rpm is your clutch currently engaged? It should begin to grip at about 8000rpm, set in warm condition. You also have to make sure that all three arms of the clutch open at the same time. It is also the exhaust is not ideal for this engine, it would have a shorter and thicker exhaust to be mounted.
And with the 14mm carb you will never get the full power of these engine. You can run a 17-19mm carb.
Chrisi's Avatar
Exhaust should look like this ons
post #57 of 125 (permalink) Old 08-16-2019 Thread Starter
Kimjon's Avatar
I'll look into it and find out.
Kimjon is offline
Yes, you have to take the engine out and split the cases. The china bearings and seals are junk, get the numbers of them and seal size. I bought SKF bearings and Dupont red Viton shaft seal, after mine failed and destroyed the whole engine.
Chrisi's Avatar
You will need 2 pc 6203tn9/c3 bearing for crankshaft
2 pc sealring 17/25/4
2 pc bearing 627 2Z for waterpump
1 pc sealring 10/18/4
And you should check your squish clearance maybe to high.
&#x1f37b;&#x1f37b;
post #60 of 125 (permalink) Old 08-16-2019 Thread Starter
Kimjon's Avatar
Thanks guys, perfect information. I have an SKF dealer nearby my work.
For now the leak has gone, so I'm going to run it this weekend.
I went through all the boxes of parts I got when I brought the pocket bikes. There's about 4 complete carburetors in there. Ill measure them up and look for a 19mm one.
I also ordered a 78tooth sprocket and a chain last night and should have it by Tuesday. It takes me about 45 minutes to machine the centre out of the sprocket to fit my rear axle and to redrill the holes to a larger PCD. I think it will make a big difference going from 68 to 78 teeth. I also found a few different clutch sprockets of 6, 7, 8 teeth. I can't recall what is on the front...but if it's more than 6 teeth, I change that out to a 6 tooth to get more lower end torque.
Kimjon is offline
