Blata B1 port timing vs B1 Rep port timing - Pocket Bike Forum - Mini Bikes
post #1 of 26 (permalink) Old 03-24-2006 Thread Starter
Scooby's Avatar
I have now measured the port timing on a B1 rep to compare with an original Blata engine,the first pics are the equipment/setup I used, the dti gauge is just to ensure the piston is at tdc to zero the degree wheel,the third pic are the results.
Scooby is offline
post #2 of 26 (permalink) Old 03-24-2006
steveg's Avatar
Images: 3
Re: Blata B1 port timing vs B1 Rep port timing
Interesting that the Chinese version evacuates the cylinder sooner and stays open for a 12 degree longer moment and as interesting the Chinese version opens the boost port 5 degrees sooner and holds it open for 10 degrees more than the original too...think they planned to let it breath a little deeper or did somebody mess up the casting dimensions
steveg is offline
post #3 of 26 (permalink) Old 03-24-2006
steveg's Avatar
Images: 3
Have you split the crankcases on those engines ? Hows the rest of the castings comparing ?
steveg is offline
post #4 of 26 (permalink) Old 03-24-2006
cagaroni's Avatar
thanks for that info... good comparison.. i too would like to see internal pics of the blata case & cylinder if you have them..
cagaroni is offline
post #5 of 26 (permalink) Old 03-25-2006
majorjam's Avatar
Images: 6
i have two b1r engines and the port timming is different also what base gasket has the b1r compared to the blata ?
majorjam is offline
post #6 of 26 (permalink) Old 03-25-2006
A.K.A. Doctor Dellorto
bike mad yank's Avatar
Images: 25
While you're at it, could you have a look at the flywheels of both and tell me how much difference there is in timing advance between the two? Also if you have access to some timing equipment, could you investigate the dynamic timing advance when the engines are running? Reason being, there is some controversy over the validity of using advancing keys on b1reps. My engine runs better with one but I'd like to get to the bottom of this question.
You don't stop laughing because you grow old . You grow old because you stop laughing
bike mad yank is offline
post #7 of 26 (permalink) Old 03-25-2006
cagaroni's Avatar
curious about the difference in port area size also...
cagaroni is offline
post #8 of 26 (permalink) Old 03-27-2006
i suppose they didn't "plan" anything. they just messed up the exhaust port's position (around 1.5mm towards the cylinder top), therewith messing up the whole cylinder design.
r
rasputin is offline
post #9 of 26 (permalink) Old 03-27-2006
i cracked a few cases open and took a few pics 2/3 months back
there are 2 different shapes!!
guess which ones match the barrel best
the one with the angled port join came with my engine that has a "2 cast" barrell fitted
the other one is what came with the bike.......
Sticky-Micky is offline
Race207's Avatar
the pic's werent' there.
Race207 is offline
cagaroni's Avatar
no pics....
cagaroni is offline
NaSa's Avatar
Images: 41
i can see them just fine...
C1 / B1-rep Tear-Down and Rebuild Info /w 400+ Pictures
Set your "Squish" HowTo: /w 70 Pictures
Technical Editor @ Mitchell 1
NC3 / S-Tech Certified Technician
NaSa is offline
cagaroni's Avatar
cagaroni is offline
cagaroni's Avatar
you must have google vision
cagaroni is offline
cagaroni's Avatar
i see them now.. had to wait for the link to redirect, copy & paste wasnt working... those are both of a c1 though??
cagaroni is offline
yes they are both c1 engines
although i tok one pic upside down by mistake
if you look at the pics badazz posted of the c1 engine a while back from inside, the parts that do not match need ground back
on the engine pic i posted 1st you can see the transfer join is cast into the correct shape so this work is not needed
and this forum is so ****en *** with outside links IMO
steveg's Avatar
Images: 3
r
I don't think they messed it up too bad as I've never heard one popping or expelling unburnt fuel...one of the tricks of 2 stroke tuning is raising the exhaust port so as to evacuate the cylinder sooner and I've read somewhere that tuners were applying that trick to the real deal B1's.
steveg is offline
for a powerful and well-performing engine you need ports that have the correct port timing and the correct ports cross-sections. the scientifical approach to this is called "time-area calculations".
example: while a straw is great for sipping a cocktail, it's just too small for drinking a pitcher of beer within one minute. you might use two straws, or even more, but you'll soon discover that the cross-section becomes too big to suck the beer into your mouth. so you have to agree upon a compromise, i.e. "five straws for best drinking performance".
the same thing is valid for engine ports. at low rpm they're too "big" to flow properly, at high rpm they're too "small", throttling the engine. the range between these two rpm is called "power band". regarding the cylinder, the transfer ports have one such power band, and the exhaust port(s) has/have one such power band. the secret for a optimum performance is to combine these two power bands in certain ways.
the blata cylinder is properly engineered, the two power bands are ideally "in tune", resulting in a wide power band.
the chinese cylinders feature the same port dimensions, but different timings. the two power bands are not "in tune". this means that at low rpm the transfer ports are "okay", but the exhaust ports are too "big", and at high rpm the exhaust ports are "okay", but the transfers are too "small". and there's no way one can eliminate that.
the c1 engine is still able to "produce" a lot of power, but it will never perform as well as a blata cylinder.
r
rasputin is offline
Images: 25
"the blata cylinder is properly engineered, the two power bands are ideally "in tune", resulting in a wide power band."
within the confines of mass production tolerances, of course.
Blata 2.5 vs Cagllari hayabusa Air Cooled Pocketbikes 41 04-25-2009 02:47 PM
How to differentiate Blata B1 and Gagllari B1 Twitch Water Cooled Pocketbikes 11 01-18-2008 12:58 PM
Port Timing On C1 Rep bike mad yank Water Cooled Pocketbikes 30 11-03-2007 02:59 PM
Port timing 911 rep andrewdn Water Cooled Pocketbikes 1 10-01-2005 03:53 PM
How To Degree Port Timing RBROHNER Air Cooled Pocketbikes 3 09-28-2005 10:16 AM
