AV Gas is designed to run in the cooler thinner altitudes and most dont mix too well with 2 smoke oils....Youre basically gonna have to almost double the jetsize in the mainjet to get it to run in a cag.....
Theres more work involved with getting the AV Gas to run correctly for too little reward....Not to mention its not worth doing if youre not gonna use the stuff everytime.................
I used to run juiced-up premium in most of my stuff til they pulled toluene off the shelves here in NY...........Now I get the 100 octane CAM2 racegas they sell a couple towns over from a pump.I juice it up with a lil Lucas and 108 Outlaw aswell as a shot of lead substitute to eliminate friction to the highest degree....
Unless youre running a compression over 180 do you need anything stronger than some good old 93 octane juiced-up a bit with some 104+ to get a little kick................Good Luck
