Don't know what marks work, but put the engine on TDC compression stroke. I mark the chain and one tooth on the timing chain so when I put it back that tooth and the mark on the chain should line up. Do not let the chain drop off the crank gear below, keep the chain tight when you pull the head or cylinder and pull it over the front of the engine and tie it off below while it sits, so the chain stays on the gear. Never turn the engine over after you take it apart, it should stay on TDC compression stroke.
