1 - 2 of 2 Posts
I am working on mounting the 19mm to a broken C1 intake manifold, by grinding the face of the rubber steel manifold flat and mounting the Cag alum manifold to it and then to the 50cc Blata rep engine.
You will notice the manifold is mounted upsidedown so it will be level on the engine. Threre is no pulse hole on the carb, it has purge fittings so it's block in the front, and with it bottoms up, the boost and purge fittings will be on top.
Discussion Starter · #2 ·
Here is a progress report w/ photos on The C1 w/ 19mm Walbro. I ground the steel / rubber manifold flat. The top 2 bolts of the alum manifold will come from the back side as countersunk screws. The bottom 2 will go thru the alum manifold, C1 rubber manifold thru the reed plate and into the case threads, and the 2 top bolts on the C1 manf. into the cases threads.
1 - 2 of 2 Posts
