Youre gonna need a 40 pilotjet(idlejet) and for the mainjet youre gonna need around a 100-102 with the c-cliop in the 3th notch and the a/f mix screw set to 2 1/2 turns out for a start............
Some carbs are jetted with 15/92 for 2 stroker bikes and have a 2 stroke atomizer tube with around 8-12 holes instead of the 20 hole atomizer tube 4 strokes use so you may need to purchase a bigger atomizer tube aswell as a needle to match the new atomizer tube taper.......
The other thing could be wicked airleaks or a wire that got pulled when doing the job...ckeck for fuel in the tank and carb bowl and check for spark....Good Luck
Got a listing for the carb youre using?
