39 and 47cc Pocket Bike FAQ
This FAQ is a compilation of information from many forums, websites and people. The purpose of this FAQ is to help someone who is just breaking into the sport, get a fair understanding of how these bikes run and what's needed to keep them running.
I hope this helps everyone out there, and I'm sorry if I haven't mentioned your name, if I used your information please let me know and I will gladly add your info! If you cannot find the information you are looking for in this thread, use the SEARCH feature right here:
http://www.pocketbikeplanet.com/search.php
Section 1
The Basics!
What is a pocket bike?
A pocket bike is what it says it is, a miniature version of a real GP racing motorcycle, it just doesn't go as fast as one. There are many different makes and styles available, many of which look just like real racing bikes. They stand about 15 to 18 inches high depending on the model and brand and they weigh anywhere from 35 to 55 pounds. THEY ARE NOT TOYS!
What is a pocket bike for?
A pocket bike is not just your average ride around everyday scooter. A pocket bike is a high performance tuned racing machine… believe it or not! It must be well cared for and must not be misused or abused in any way.
How fast are these things?
Depending on which type you get will depend on the speed of the bike. The speed also varies according to the rider’s weight and road conditions. Most pocket bikes are capable of doing anywhere from 28-50 MPH.
What kind of protective gear do I need?
You should invest in a DOT approved helmet, pads and a body suit. Going at 25mph + does tear jeans and leave some pretty bad cuts and scrapes. NEVER ride without a helmet...Not only do you look stupid but you WILL hurt your self.
Do I Need A License?
These bikes are not for road use, so driver's licenses are not necessary. See your local DMV website or office for more information.
Can I Ride My Pocket Bike On Public Roads?
NO. They are not street legal. They do not possess headlights, turn signals, and brake lights. And do not have Department of Transportation approved tires (since they come with racing slicks). There are smaller 50cc bikes that are street legal, but again they tend to be larger and slower.
How Much Power Do The Bikes Have?
Stock is around 2.6hp. Simple modifications as mentioned on the parts page, including the Stage 1 2 and 3 kits, can increase power to 3.1hp at the tire. It is likely that the motor is actually generating 20% more than that at the crank. These engines are capable of more power than that if you are interested in spending the money for engine work.
What kind of motor does a Pocket Bike use?
Pocket bikes have 2-stroke engines.
Section 2
Technical
Well I have my pocket bike… what now?
Following the following steps will ensure that your first ride wont be your last!
1. Clean out your tank and flush with fuel to get any debris out.
2. Clean out the carb to assure it is free of debris.
3. Move the needle clip on the carb to the 5th position, which is the bottom notch if the needlepoint is pointing down.
4. Get an Air filter
5. Check your tires to see if they have enough air. 28lbs seems to be right.
6. Make sure all fasteners are tight and secure, possibly add loctite.
7. Make sure the gas cap is in some way vented so the tank does not vacuum. (Use a pin to punch 2 holes in the cap)
8. Make sure chain is well-lubed
9. Adjust your brakes so that they are not dragging too much, especially the rear. A dragging rear brake can cause your clutch to fry prematurely or break a clutch spring, among other things.
10. Mix your oil/fuel mixture accurately with good oil meant for 2 stroke bikes
11. Check over the engine bolts and steering head bolts for tightness, make sure wheel and steering head bearings are functional and not sloppy. Do not over tighten your foot peg bolts because they frequently break off.
12. NEW riders, read the starting procedures
13. Starting the bike- To properly start the bike, make sure the fuel **** is open, the choke is on, if the engine is cold. Make full complete pulls to the engine, while adding a little gas. Caution, do not add too much gas, your bike will fly out of control if it is not started on the stand! Even if you're starting it on the stand, it is not necessary to add too much gas. Once the engine has started, you can not turn the choke back to A if it was on the choke. Be sure to warm up the bike for at least a minute before riding off into the sunset.
14. Have fun!
Will it operate on pump gas?
Yes, premium pump gas should be used. Use fresh gasoline only, do not use any gas that has been stored for more than 2 weeks. Only mix enough fuel/oil that will be used for the day or weekend.
What oil is best to use?
Any good quality (brand name) pre-mix 2 cycle oil, preferably synthetic
Good oils:
Any good fully synthetic oil is fine.
1 pint = 16 oz
1 liter = 33 oz
1 quart = 32 oz
Example:
3 pints = 48 oz
3.2 oz = 15 fills [40:1]
2.6 oz = 18 fills [50:1]
General guide for the number of Oz to be mixed in one US gallon and what ratio it comes out to be.
50:1 = 2.6 oz oil to 1 US gallon of mid grade gasoline
40:1 = 3.2 oz oil to 1 US gallon of mid grade gasoline
32:1 = 4.0 oz oil to 1 US gallon of mid grade gasoline
By fills I mean the number of gallons you can mix.
What do I use to flush out my tank?
Whatever mixture you plan on using (ex. 32:1, 40:1 or 50:1) Use that same mixture to flush out the tank.
How do I break in my new Pocket Bike?
Start with a 40:1. Don't full throttle it and don't keep the RPMs at one speed. You want the RPMs varying up and down. Let it cool down after every 10-15min. of riding. Run the second tank on 40:1. After that switch to 50:1 using full synthetic of your flavor.
What position should the choke be in?
The choke should be in the upward position when your doing a COLD START, and it should be in the down position when your riding or doing a WARM START.
What is the difference between air-cooled and water-cooled?
Water Cooled tends to last longer between rebuilds, because the engine runs cooler - but 40cc class European racers used to favor the air-cooled bikes because they could be a tick faster...having less parasitic loss (no water pump drag), and less weight (no pump, radiator, brackets, hoses, overflow bottle, and water).
Is my spark plug fouled?
http://www.nightrider.com/biketech/spkplghnbook.htm#In
Fouled:
http://www.nightrider.com/biketech/images/oil.gif
Section 1
The Basics!
Section 2
Technical
14. Have fun!
Good oils:
1 pint = 16 oz
1 liter = 33 oz
1 quart = 32 oz
Example:
3 pints = 48 oz
Fouled:
