1 - 4 of 4 Posts
I currently have a 40cc 4 stroke bike with a epa non adjustable carb. Is there a way to swap this carb with another or is it just not compatible with a 40cc engine.
If pictures are needed I will send them. Thanks
if you want to be a guinea pig you can try this carburetor its next in line of the carburetors to try undetermined of aftermarket carburetors as of right now keep in mind the stock carburetor is 10 mm
Echo SRM-261SB RRT-260 PB-260L SRM-260S PAS-261 PE-261 A021000700
if you do decide to blow the 10 or $15 on a wham make sure you come back and let us know if it worked or not
https://www.ebay.com/i/123563417920?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=123563417920&targetid=885333805405&device=m&mktype=pla&googleloc=9029652&poi=&campaignid=9418894964&mkgroupid=92908006262&rlsatarget=aud-622027676388:pla-885333805405&abcId=1141016&merchantid=112006992&gclid=Cj0KCQjwoPL2BRDxARIsAEMm9y_WBvuawxb0D-7j9PxiHq9cKqSbIi_0AZDJrDMAVH8_WZezcqf7VzcaAv0xEALw_wcB
Will do! also it comes with the air box with the small square hollow type of filter. is there anyway i can swap out the choke plate to have one that would support a aftermarket air filter? I bought an aftermarket airfilter when i first got the bike but the little prong type things on the plate were plastic and couldnt support it without it slipping off. Thanks
1 - 4 of 4 Posts
