I don't even know if the one ring piston will work. This is a 30mm stroke my C1 has a 37mm stroke, and maybe more time to build compression. Haven't had a degree wheel on it, all I did was grind the top of the piston down to clear the 17:1 dome shelf on the ADA alloy head, plus took some off the bottom to clear the crank & to open the feed to the main transfer ports. I did not want 17:1 so I ground the first angle change in the cap to a more hemi shape, to get down to about 16:1. I have all kinds of 44mm Cag pistons I have modded already if the Husqvarna piston don't work right. I have a 40mm 2pc cyld kit with a 10mm FC crank & stock Cag cases with NaChi bearings and SKF seals w/ a 40mm one ring Husqvarna piston and a modded V reed block w/ a WT-668 walbro I am working on too. The 10mm FC crank is in the mail, I hope.
I bought a 180cc 61mm big bore kit & high angle cam today for my GY6 BMS 150cc scooter. Confused on the rollers and variator plate I have w/ 14g rollers, that says high performance, and they sell, 9, 10, 11, 12 and 13g ones too, and some are not round??? The have 3 racing clutch springs $25, and a whole hp clutch assembly for $66, and then there is the belt to, there cheap ones and good ones, was thinking about Kevlar belts, but I will deal with that part later. The thing is fun to ride, but don't like the idling when the gas is off your coasting, can,t wait for more power,lol.
