1 - 20 of 27 Posts
This is my project that im working on, last week i picked up a little 49cc dirtbike for 80€ it already had a bigbore kit on it.
Tire Wheel Automotive lighting Automotive tire Vehicle
Footwear Tire Bicycle wheel Bicycle Wheel
my goal is to put street tires on it and a exhaust that goes under the bike. and make a Sm out of it!
Wheel Tire Bicycle tire Motor vehicle Automotive tire
this is what im working on now its a Bidalot/Technigas pocketbike exhaust. customized it a bit to fit it.
Arm Leg Human body Plumbing fixture Human leg
these are not my best welds but there atleast strong enough. its hard to weld 1mm thin metal with a stickwelder.
Wood Office supplies Natural material Household hardware Metal
almost finished cleaned it up a bit.
this got my inspiration to make an exhaust under the bike like this:
Tire Wheel Fuel tank Automotive lighting Vehicle
its an derbi senda moped. not my bike.
i also want to buy a 4 petal reed kit which costs 80€ on aliexpress, but is it worth the prise for power increase and is it noticeable?
Hand tool Tool Metalworking hand tool Font Auto part
i also flow the engine cases myself for better fuel flow.
Camera accessory Film camera Gas Cameras & optics Auto part
Bicycle part Rim Vehicle brake Bicycle drivetrain part Auto part
Let me know what you guys think of this project!
Yours will come out far better than mine. lol.
Here's a link to what I did to mine, if you need any suggestions.
I like the project. Can't wait for the final product.
As for your reed setup, I remember reading they don't work as they are expected to, especially for the cost.
But give it a try and let us know.
Yes i can imagine, im quite busy working on it and i even bought some Kenda k313 street tires for it. now i gotta wait till they arrive and put it on the rims.
i do wanna buy the reeds but i also dont want to waste any money on it. maybe i can make a reed cage my self.
but i think the 4 petal reeds can work properly if you put the right carburator on it and if you flow the cases right, and a good exhaust aswel. i already have a 19mm dellorto rep carb from aliexpress that was only 16€ with shipping 😂. most of the parts i bought it from aliexpress because you can save alot of money then by buying it from a local shop, only the delivery time is quite long about 2-4 weeks.
i took a look at your syxmoto project and it looks good, i also want to put some hydraulic brakes on it because the stock ones are total garbage.
i see that you also put some kenda scooter tires on it and i was also looking for the same tires but i cant find them anywhere on the internet. so i just bought the kenda k313’s not what i was quite looking for but i had no choice.
Discussion Starter · #7 ·
im also working on the cylinders by enlarging the exhaust ports to match up with the exhaust flench:
Automotive tire Gas Household hardware Composite material Rim
this is my 19mm carb, yes it has some bad machining but its normal for the price, i will smoothen it out with some sandpaper.
Textile Sewing Sewing machine feet Sewing machine Household appliance accessory
Finger Auto part Household hardware Gas Nickel
I have the Kenda 329 in 2.5-10 and 2.75-10. It rubs a little on the chain, though
Discussion Starter · #11 ·
So i’ve been working on the exhaust mounts and it turned out pretty good. only the welds dont look like the best ones in my opinion, ive done better welding jobs than this. but its strong and it took me about 2/3 hours to make sounds a lot for what it is but i did it in the evening and a had to bend the exhaust mount quite a few times and grind off some metal aswell. final result of the exhaust mount in the rear:
Wheel Tire Fuel tank Crankset Automotive lighting
Tire Wheel Land vehicle Automotive fuel system Vehicle
The only thing, to me, is it hangs a little low, when you are offroad and hit a bump and the suspension compresses you might rip that exhaust right off. It looks like its only a few inches off the ground.
Discussion Starter · #13 ·
yes i know, it looks like it hangs a little low because it has a pocket bik front tire on it right now. im only going to use this for the road bacause its a SM build.
Discussion Starter · #17 ·
Tire Wheel Bicycle tire Automotive tire Motor vehicle
Hello everybody. it has been a while, i’ve been quite busy with school lately but sometimes i’ve been working on my project. Got some really good news.
I flowed the engine cases a bit too much atleast thats what i thought
sorry i dont have any better pictures. but i thought i removed too much material. yesterday i put the motor back together and i also fixed the reeds like i did last time same method, i removed the middle part of the reedplate so it lets more air and gas through and it works really well. today i got it running, It runs pretty good and starts in one pull. but it has alot of vibration and i dont know where its coming from.
Automotive tire Motor vehicle Alloy wheel Bumper Audio equipment
i also made the exhaust port a bit bigger and the ports aswell.
1 - 20 of 27 Posts
