The motor fires up briefly when I manually inject fuel through the throat
of the carb. Will not fire up otherwise. I have completely cleaned the
carb twice. I siphoned the fuel line to make sure that the fuel is available
at the carb fuel inlet. I also have purge pumped the carb (repeatedly pressed the plastic bulb at the bottom of the carb). I have been working
on small engines for four years, but this one has me totally at a loss. Any suggestions?
