Hello all,
I have the exact same bike as in the picture. I used it a couple of time, every time I found starting the bike very hard. I even broke a couple of pull starts already and I just think it doesn't make sense.
I am trying to understand where the problem is and why the pull start is so jerky, so this is what I know so far:
I'm no expert, but my assumption is that if with plug out and the flywheel rotating smoothly, it means nothing is wrong with the piston? Do I have the right assumption?
If so, then what's causing the jerkiness? I've placed back the plug and I tried a couple more things:
The last thing I can think of is that maybe the reed valve is blocked? Does that make sense? What's the best way to troubleshoot this?
I know it's a long post, any help appreciated!!!!
- Trying to start the bike, the pull start feels very jerky and fairly hard
- Rotating the flywheel by hand, it still feels very jerky and hard
- With the plug out there is decent spark
- With the plug out, the flywheel is very easy going and smooth, no jerkiness whatsoever!
- Disconnect the exhaust from the engine outlet - the flywheel is still very jerky. I placed my finger softly inside the exhaust outlet and felt the piston moving with no problem.
- I also took the carb off, and tried the flywheel and it still feels hard and jerky.
