1 - 2 of 2 Posts
Everything works lights horn blinkers .my question on the side where the pull start is there is a tab coming off with a heavy red cable then there are 2 black cables one being hot not connected to anything I can see and my electric start don't work help please!
That lug coming out is positive when it's running you should be able to put a meter on it and see the voltage the engine case is ground.
To test the starting function clamp one negative jumper cable to the engine case for ground hook up positive and negative to a car battery with the car engine not running touch the positive jumper cable to that lug coming out if it spins over then the starter motor is good. If it doesn't spin over or has a hard time turning the engine your starter motor is dead.
1 - 2 of 2 Posts
