ADA Stalker Exhaust?
2322 Views 23 Replies 4 Participants Last post by  BBC
Was surfing the net eariler and came across what seems to be a pretty bad *** exhaust.. if it was actually functional.
Code:
http://www.ebay.com/itm/Exhaust-ADA-Racing-Stalker-49cc-Pocketbike-Midbike-Bike-/320930491107?pt=LH_DefaultDomain_0&hash=item4ab8f2aae3
^ check it out. Debating on it, but wanted to see what everyone else thought.
I like trying new things i guess.
1 - 20 of 24 Posts
Its a descent exhaust but youd get better gains with a fatty pipe and a juicebox intake.............
okay. imma get some new accessories tomorrow and widen the holes a little bit and use some exhaust paste to fix the tiny hole on my exhaust. Also seem to have misplaced one of the exhaust springs.
Think home depot would have one like i need? Work a check regardless. The paste says its good for up to 1000f, so i think we should be alright, no?
Hey bbc , how's ur bike?
Nice.................Home depot sells springs......The paste should work if the repair is done well enough........
Speaking of springs, I found a perfect pusher spring from a old Airsoft but when I tried to install it, I noticed it was a tad too big ,I have to find someway to adjust the spring
Engine is getting shipped tomorrow after work.. Then i will let sam do his magic, and hes doing a little extra for me. want to repair my exhaust and hide all wiring in the frame by the time he gets back.
Will be updating the build thread tomorrow and friday
How much is he charging?
Sent your engine to Sam, great move you won't be sorry. Mine sounds like a buzz saw, on steriods,lol. Good move on the exhaust, just fix what you got.
Lol wat bike did he mod?
He's charging 100 but im giving him like 130+, just haven't figured out how much exactly, he's doing much more than just porting it.
With a fresh topend I always start with a fresh coil.............The two kinda go hand n hand..........
Wow! U must have a lot of money to trust some random person whom uve never met with ur engine and some money!
Nah man I don't have alot of money, but if he's spoken so highly of from epr and cam2, then that's good enough for me
So r u keepin ur bike once it's done?
Most likely. If i fall in love yes, and thank you CAM imma order one now. gotta get the new sparkplug and wire too
Actually, cam, can you point me in the right direction? Where exactly is the coil located
Right here under the plastic shroud........
The piston ported coils dont have a wire that unscrews...to add a hp wire you have to do a super mod to pull it off............Get a NGK BPMR7A plug
super mod? forreal? ****. how much would it help?
also, do i need 2 inch or 2.5? I dont have my engine in front of me anymore to check
1 - 20 of 24 Posts
