And this is why N!p is a valued Member here at PBP!!!!!!Bypass everything........ lol make a new wire from the battery to a fuse, to a switch, to your lights and ground.... lol The easiest way!![]()
If the handlebar switch doesnt get power you need to look into the fuse holder.....Pull the plug on the fuse holder and put a jumper wire in the harness plug to bypass the fuse to see if thats the problem........ok so the light wont turn on so when i turn the switch the bike turn onthe bike wont turn on with out the keyswith turn on so how do i test without a meter is that possible i really want to get this lights working to day
also if the handle bars dont get power what do i replace.
last thing so how does the speedmeter work on this bike there no manget thnks every got it to work
