Have you had problems with the brake discs on your b1 rep not floating freely? I’ve tried adjusting them but they seem to rub no matter whatI’ve had this MT-A4 B1 rep for 3 weeks or so now and finally got to take it out last night. Drove out to a go kart track, running late, far away. Didn’t get much time but was a nice little taster. I’m going for a 4 hour session tomorrow.
The bikes looking real good in my opinion. I pushed the coolant reservoir out with a straight bracket and new hoses. This allows me to have the clip ons pretty much straight but still turn lock to lock both sides. A few R6 stickers here and there as I have a red n white R6 aswell for when the weather isn’t so bad lol.
The bike seemed to run well for about 2 laps, I was only on around 3/4 revs as I’ve still got to run in the bike but the powerband was kicking in nice. Then it just kind of started to bog and lose power. I pulled in, she didn’t sound as healthy and kept cutting out. I kept running it on the stand l, fiddling with the idle screw to try and get her nice. I did buy this ram air foam air filter and had laced it with air filter oil (as you do on mx bikes) and thought this is possibly starving the engine of air? So took it off for a minute and the bike seemed to be okay then. Eventually put the filter back on and she ran like a dream again. Got another 10-15 laps in. Still not full revving but the powerband felt good.
So far mod wise I’ve literally just swapped out the stock plug for an ngk b9egv I believe it was, as suggested in the manual. Replaced the tin reed petals for carbon ones and then swapping out the standard filter for that big foam ram air one. I bought a 72 tooth rear sprocket last night aswell after being recommended by one of the lads there. I’m currently waiting on an rpm gauge to set my clutch correctly and also a digital micrometer for setting the squish.
Anybody got any other suggestions for mods for speed, reliability, etc apart from a dellorto carb which is in the pipeline? Just want to make it as good as it can be really. The track I’ve took it to has a proper mini moto shop with all the spares and performance parts btw.
Another quick one aswell. At some point my choke lever stopped locking into place. I haven’t really needed to use it but I remember when I first got the bike, if you put the choke on, it would lock into the down position. You would have to push the lever to the one side for it to spring back up and turn the choke off. Now it won’t stay in the down/on position. It just springs straight back up. Any ideas? Ive tried to look to see how it works but I’m not quite sure.
Thanks everyone for all your information. Hope you like the bike 👍🏻
