1 - 8 of 8 Posts
Ok I took off my back tire and I got everything mixxed up and I dont dont know what goes first.I got an axle a thing that the axle goes in a washer and many other things does anybody know how it is suppose to go.
From the rear of the bike, the bolt slides thru the left side of the wheel.....example of a h/f Cag.
So it goes like this:
Bolt -> chain tentioner -> slides thru hole in chassis (left side) -> wheel spacer -> wheel -> wheel spacer -> rear brake assy -> hole in chassis (right side) -> chain tentioner -> washer -> nut
:thumbsup: Daren
I think the two wheel spacers are different lengths. Correct me if I am wrong here, but I believe the left one is shorter then the right one. This is what I recall the last time I removed the wheel off my f/f cag. I can't remember if my h/f was this way. It's been a while since I removed the rear wheel off that bike.
Actually the longer one goes on the sprocket side and the smaller spacer on the brake side...
eddiemcrider said:
:thumbsup: Daren
Thanks fella's....last I recall, I didn't notice a difference. tho' when I worked on them (Cag's), I set them to the side in which I dis-assembled.......left side stuff to the left of the bike, right side stuff to the right of the bike :p
Makes sense now thinking about it...because of the brake assy on the right side or could I be wrong......hmmm
Yeah that makes sense - the brake assembly takes up some "space" on the right, so it requires the smaller spacer. Like Cali when I take things apart, left & right side parts stay on the side they were removed from the bike.
1 - 8 of 8 Posts
