Welcome to the site ! Can't wait to see ur bikes!
Thanks! what can i say i love them both for 200$ i just want to ride her so bad, i dont like watching my leather jacket collecting dust. I will post more pics as it is restored more. asapNice x2 bro! I have the same bike
Strip the bike of all wiring...I gained a loss of 12 lbs by removing the gauges,,switches,,battery,,wiring and gutting the e-starter/generator on my X1,,,after full mods I took a bone stock 26mph X1 and made it cruise a tick over 40mph..........The starter pushbutton doubles as a killswitch when hooked to the two wires coming from the coil........I see that may be why we have been having problems matching up parts for the X-2 , i planned on installing a rocket key on both, the main problem the x-2 wont start it is leaking gas like a mad man from the carb and the tank , the x-2 sparks it starts for a good second or two and evrything electrical is completly disconnected i cant even find the connectors for any of my turn signals etc also we have been using the pullstart unless fuel is injected into the engine we cant even start it
My Homemade stand-up scooter has a powerplant from an X2 but the engine is highly modded and so is the CVT transmission
If the carb is leaking badly its gonna need a rebuild kit..you can buy a cheap chinese carb on ebay too but the insides will still have that same crappy inferior internals...once you throw a real walbro kit in there and port the carb inlet and outlet youll gain alot of performance by turning that carb into a performance carb
should i be careful with sites like scooterparts4less.com? im not really going to rage over a 10$ price diffrence i just need a place that i suppose isnt going to just send me whaever they feel likeSee if you can find a supplier that will take a USPS money order, order your parts and send the money order. PBParts in Florida has a phone.
The carb needs to be removed,,,and one thing i dont get is why the cag wasnt leaking and now it is, but the plug on the gas tank of the x-2 needs to be replaced unless i want to lose gas when im over a tank and a half
yes the fuel lines are fine its the seal on the carb so i am just going to buy a new unit, both of them were drained when i purchased them and the onwner as well a others told me to use unleaded 50:1 which is what both of them have in the tank , i will get on the mods as soon as i can get someone that knowledgeable to help since im not exactly the best mechanic yet or anywhere near, thank you i will memorize all of whats here and post the results very soonThe carb needs to be removed,,,
The petcock mod should be done,,
The carb needs to be totally cleaned inside,,
The float forks must be set right
The float needs to be installed right...The hump in the float goes to the bottom of the floatbowl....
I go the extra step and sand the mainjet casting and polish iy so the float rides up n down smoothly
Once you take the time to make them work right they work pretty descently but alls ill say is get used to the gas on the floor unless you upgrade to a retrofit hp pumper carb setup...........
On the carb on the x2 thats been replaced and is leaking again......
Are you sure the 2 fuellines arent cracked and are tightly fit onto their right nipples?
Did you drain the tank and use a fresh premix of 40:1 premium fuel?
Try tapping the side of the carb to jar the pumper needle in the carb that maybe hung up and stuck a lil.........Good Luck
what about the wiring from the engine? did you just snip it, also im missing my electric start button
I gutted my e-starter and cut the 10ga red wire from the starter housing..,,The rest just unscrewed and unclippedStrip the bike of all wiring...I gained a loss of 12 lbs by removing the gauges,,switches,,battery,,wiring and gutting the e-starter/generator on my X1,,,after full mods I took a bone stock 26mph X1 and made it cruise a tick over 40mph..........The starter pushbutton doubles as a killswitch when hooked to the two wires coming from the coil........
Heres a thread showing how I removed the e-starter..........
http://www.pocketbikeplanet.com/showthread.php?t=58861
thanks , well i scrapped everything and put a hedge trimmer carb on there she is trying so hard to start but its smoking we believe its the bearings inside the engine burning up since the sprocket will turn just not the internals, working on that next but i have no engine bearings at allI gutted my e-starter and cut the 10ga red wire from the starter housing..,,The rest just unscrewed and unclipped
4:54PM well pretty sure the bearings are blown out but i cant crack the casing on the engine yet, the cag is currently in stock perfection, i cant wait to apply those modifications
Remove the transmission from the engine..Youll most likely find a delaminated clutch pad or busted spring........thanks , well i scrapped everything and put a hedge trimmer carb on there she is trying so hard to start but its smoking we believe its the bearings inside the engine burning up since the sprocket will turn just not the internals, working on that next but i have no engine bearings at all
