1 - 4 of 4 Posts
I was wondering about the RPM Engagement for the clutch. I know it's important to adjust it so the clutch engages at 8000, but no more than 8900. Is it ok to adjust it to engage lower than 8000?
You know, I had wondered about this also. I wanted mine to engage at about 5-6,000 while I was getting used to the tremendous horsepower, and learning to ride.
I was told that having it engage too soon can cause excessive heat build-up. I don't really understand how this is possible. Without friction, I can't understand where the heat would be generated. The torque alone pressing on the clutch drum should not create heat, as it does not have much power at the lower RPM's.
This would certainly limit the acceleration while waiting to get "on the pipe", but I do not see any other drawbacks. I am a very systematic "thinker", but I am not a pocketbike mechanic, so you can take it as such.
Roy
That's kind of my thinking of limiting the engagement RPM too. With this bike, the power over what I had before (Cag) I am having to learn how to ride all over again!
Roy
Check out the clutch tips on www.minimotogarage.com
You can have the clutch engage at a lower rpm... but it does build more heat. Just because it enganges soon dont mean it dont slip. the slipping causes more heat.
1 - 4 of 4 Posts
