Hi,
I haven't started up my X7 Pocket bike, in months. So I took it a part and cleaned out all the jets and the rest of the carb and got it so it will start up. I also replaced the spark plug.
I cannot seem to get it to idle. I have tried the fuel mixture screw on the carb in about a million different positions. I have also tried the idle screw a million different ways. I also adjusted the float to where it was set before, which is just slightly lean.
I can only get the bike to idle when the choke is fully on. I had this problem about a year ago, and I thought it was because the bike was running too lean but apparently it was running to rich.
Do you think it is possible I need to adjust the throttle needle to a different position?
Any help is needed! Thanks!
