The rear does not spin when I pull the rope. Clutch engages everything is working, but I'm trying to get this clutch cover off so I can clean and install new springs. I will update on here!Does the rear wheel spun when you pull the rope??
If so the clutch is most likely oxidized to heck....
I suggest to soak it in a pan of wd40 overnight then with heat from a plumbers torch get it to budge ...
